Oil in Throttle body
Old Apr 8, 2012 | 03:38 PM
randyb's Avatar
Default Oil in Throttle body
My 01 XK8 has oil in the bottom of the Throttle body, anybody have and good ideas?
i cleaned the breather on the D/S valve cover w/3/32 drill bit and cleaned the TB and I still getting oil.
Old Apr 8, 2012 | 08:14 PM
test point's Avatar
You didn't comment on the blockage found or not found.
You also didn't say how many miles on the car but oil is a sign of compression blow by past the rings if the part load breather tube is clear.
Try a can of 'RESTORE' and/or move up a weight in oil and see what that brings but a professional would do a compression test at this point.
Old Apr 8, 2012 | 09:06 PM
Spurlee's Avatar
Also, the full load breather should have a filter of sorts in the valve cover. If you can see the cams when looking into the breather hole yours is missing...
Old Apr 8, 2012 | 09:45 PM
randyb's Avatar
I can see my valves, now I am worried the filter came off or was removed.
BTW: there was some blockage but it has been removed.
Old Apr 8, 2012 | 10:15 PM
WhiteXKR's Avatar
I would take that problem any day over worn rings!
Old Apr 8, 2012 | 10:22 PM
Paul Pavlik's Avatar
I cleaned the breather on the D/S valve cover w/3/32 drill bit and cleaned the TB and I still getting oil.
https://www.jaguarforums.com/forum/x...ink-faq-67025/
Old Apr 9, 2012 | 10:13 AM
randyb's Avatar
I read that thread in my research, but my problem is with oil in the TB, not the filter, but now that I reread the thread I see the correlation.
Do you really have to buy a new valve cover or do they sell the plate and baffles separately?
Old Apr 9, 2012 | 04:56 PM
WhiteXKR's Avatar
The parts database does not show it as a separate part. If the cover was metal, I would say go for used, but a used plastic one might be risky.
Old Apr 9, 2012 | 05:18 PM
The Coupe's Avatar
In my case, I purchased a new valve cover from Gaudin for about $185. This will definitely help your problem.
Old Apr 11, 2012 | 08:11 PM
plums's Avatar
You could plumb in an external catch can. Much easier to clean.
Old Apr 13, 2012 | 09:48 AM
Spurlee's Avatar
'Vette guys do this a lot. There are trick kits available for them...
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
mrplow58
Sep 9, 2015 11:27 AM
