P0174 and P1111 error codes
Old Nov 15, 2011 | 09:22 PM
jam1white's Avatar
Unhappy P0174 and P1111 error codes
Guys i'm having a problem with these two error codes on my 01XK8. Tried visually looking for any leaks, but nothing. Any suggestions would be greatly appreciated. thanks
Old Nov 16, 2011 | 01:59 AM
xjrwithproblems's Avatar
What are you're symptoms. Any difference in driveability? Rough idle? Studdering? Loss of power? I've pretty much had every problem possible with my car and can guide you in the right direction
Old Nov 16, 2011 | 02:01 AM
Oh and btw, p1111 just means that the obd diagnosis is complete. This is not a trouble code, so don't worry about it.
Old Nov 16, 2011 | 05:42 AM
test point's Avatar
The P0174 code is reporting a lean condition on the left bank.
The usual suspect is a leak in the intake duct between the MAFS and the Throttle Body, especially in the accordion section from the exhaust manifold. You will need to remove the duct to explore that area.
Check for leaks in the full load breather, clean the MAFS, clean the part load breather orifice and clean the throttle body. Even check that the oil dip stick is fully seated. Yes, it has a crankcase seal also.
All that done leaves an intake manifold leak or a failing O2 sensor.
Old Nov 16, 2011 | 10:00 AM
jam1white's Avatar
Hey thanks guys...this car is driving me crazy. I am having some drivability problems. It first gave a "restricted performance" error, then on another day it went into "safe mode". Both times it started back up after a few tries. Also on the startup sometimes it idles rough and then picks up.
Im going to try the soap spay on the vaccum lines tonight to see what happens. Any other suggestions would be greatly appreciated. thanks again
Old Nov 16, 2011 | 10:06 AM
jam1white's Avatar
Hey thanks for the info...i will check those areas also. im about to go nuts with this car.
Old Nov 16, 2011 | 10:07 AM
WhiteXKR's Avatar
If everything else checks out, it could also be the MAFS itself.. I have seen it only generate an error code on one bank as it starts to degrade.
Old Nov 16, 2011 | 05:01 PM
H20boy's Avatar
I don't know of the 01s have Posiitve crankcase valves on the 4.0 engines, but my PCV line returning to the bottom of the throttle body was loose at both ends, the connectors have o-rings that get brittle and hard, and no longer seal. This results in unmetered air entering the TB also. Every little leak adds up.
Old Nov 16, 2011 | 07:46 PM
jam1white's Avatar
Thanks H20Boy...il check that out.
Terry H
Jul 4, 2017 05:48 PM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
