Parking Module replacement
Old Oct 17, 2014 | 10:28 AM
03xk8's Avatar
Default Parking Module replacement
My parking aid module is: 3W83-15K866-AA, I can't find a matching prefix 3W83 or suffix AA but plenty of matches to 15K866 will any module work or is it critical to have an exact match?
Old Oct 18, 2014 | 09:13 AM
My immediate thought was 'NO' because I've retrofitted Parking Aid to a 2001 XK8.
However, checking the Parts Catalogue shows the Reverse Aid Module became programmed from VIN A40265:
If your vehicle is VIN A40264 or below and the donor module comes from a similar VIN range, it should be compatible.
Old Oct 18, 2014 | 08:30 PM
03xk8's Avatar
Mine VIN is A36190 (a 2003 XK8) I've been doing the web search via part #, should I be able to find one referencing VIN #'s?
Old Oct 19, 2014 | 04:04 AM
Your VIN is prior to the introduction of the programmed module so you need to source a similar replacement and it should just be a direct plug in.
The programmed modules started with MY 2004.5. You can either search by Part Number or Model Year.
Old Oct 20, 2014 | 09:51 AM
max224's Avatar
Graham,
How difficult/expensive was it to fit the Parking Aid to your car (and was it worth it)? I have a 2007 Ford Freestyle that lets me know when I'm getting too close to the car behind me when parking; worth its wait in gold.
Old Oct 21, 2014 | 09:29 PM
03xk8's Avatar
The one that was stock in the car was water damaged. I have yet to replace it so can't give you a cost
Old Oct 21, 2014 | 09:37 PM
03xk8's Avatar
Sorry I'm tired, didn't see that your question was directed to Graham.
I also have a follow-up regarding my first post; Am I okay without the matching prefix 3W83 or suffix AA as long as matching 15K866 & the plug-in configuration?
Old Oct 22, 2014 | 07:17 AM
RaceDiagnostics's Avatar
Originally Posted by max224
Graham,
I would not fit a Jag reversing aid in your case, have a look on ebay for dirt cheap aftermarket ones that work well.
Old Oct 22, 2014 | 08:52 AM
Dennis07's Avatar
FYI, I was once suspicious of the module in my '03 and tried substituting a module from an '01. It worked fine.
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
