PECUS E error
Old Nov 13, 2024 | 12:36 PM
emmequadro's Avatar
Default PECUS E error
Good evening, I'm Paolo and I'm writing from Italy. I own a 1997 XK8 convertible. My control unit has a PECUS E error. The mechanic tells me that it needs to be reprogrammed. Do you have any suggestions to solve the problem? Greetings to all. I'm attaching a photo of my car. Thanks
Paolo
Old Nov 13, 2024 | 03:28 PM
As this is your first post, please stop by the New Member section https://www.jaguarforums.com/forum/n...-intro-must-5/ and post an intro. In return, you will get a warm welcome and useful tips to navigate the forum. As for your issue, the mechanic is correct and a search of the forum will yield a great deal of info including the attached PDF regarding the various PECUS errors
Old Nov 14, 2024 | 02:59 AM
dibbit's Avatar
Was the car working ok before this message appeared, or did you buy the car with this fault?
I think I would open up the ECM and check the state of the capacitors as they are known to start failing on the early cars, before doing anything else.
Jag_Willi
General Tech Help
Apr 30, 2024 01:14 AM
Hunnenkoenig
Apr 8, 2024 04:22 AM
Fishface
May 10, 2019 09:56 AM
Fishface
May 10, 2019 09:01 AM
WillyWheels
Aug 12, 2012 11:02 AM
