Phone ?
Old Oct 26, 2012 | 01:08 PM
David Russell Edwards's Avatar
Question Phone ?
At the bottom left of the controls (below the on/off/volume knob) of my 2002 XK8 is a button showing the symbol of a phone. When pressed a message comes up saying "no phone".
Does this mean that the car came with the capability to use a phone say hands free, etc? If so where did you plug it in etc.?
Or was it on all of the cars whether applicable or not?
Old Oct 26, 2012 | 01:11 PM
baiao's Avatar
Default phone cradle
The phone option had to have the phone cradle installed under armrest.
It was an analog phone.
Old Oct 26, 2012 | 02:48 PM
mjlaris's Avatar
That's true baiao but the wiring is present in, I believe, all XKs and some members have hooked up aftermarket hands free kits into the stock system and gotten the radio to recognize the phone. I installed an aftermarket head unit with bluetooth and therefore have not paid much attention to solutions using the factory head unit so I don't know the limitations or installation difficulty but a search of the forums should yield this information.
Mark
Old Oct 26, 2012 | 04:40 PM
ccfulton's Avatar
All cars have the wiring and buttons. The connection is under the console and isn't too hard to make use of, but you will need to splice and/or make your own connection harness.
I added a parrot Bluetooth system to the stock head unit and if you have all the pieces it's easily a weekend sort of job.
Old Oct 26, 2012 | 07:46 PM
+1
The harness and switches are present.
My last 2001 XK8 didn't have a factory phone and I fitted Parrot CK3100 Bluetooth using the Jaguar harness connector.
My current XK8 has factory Bluetooth. If it didn't, there is no way I'd consider a retrofit. Jaguar BT has two major disadvantages:
1. only allowing pairing with a single phone. if you want to use another phone, you have to go through the pairing process each and every time.
2. the range of compatible phones is limited.
The Parrot system allowed multiple pairings to be retained and integrated with the vehicle audio system. Other aftermarket BT systems are similar.
Old Oct 27, 2012 | 03:10 AM
malbec's Avatar
Graham, do you know if the Jag Bluetooth is compatible with iPhones ?
I have jag phone but was thinking of getting the jag BT, I only need to link to my phone.
Thanks.
Old Oct 27, 2012 | 03:48 AM
Thanks.
There's been recent discussion in S-Type section about Jaguar BT compatibility issues with later iPhone 4S.
Check Jaguar Bluetooth Connectivity Centre for compatible models and pairing instructions:
Jaguar UK - Bluetooth Connectivity
Jaguar BT in our models is rapidly being left behind by advances in phone technology.
Old Oct 27, 2012 | 08:36 AM
ccfulton's Avatar
It was a long time ago when I looked into the Jaguar BT module but if you can dig up the installation instructions check the part number for the phone module (the one behind the rear seat).
Not all of them work with the bluetooth module (the bit that goes under the console) and if you would have to update the phone module as well it could turn into an expensive prospect.
Sorry, but I can't seem to find the instructions to post the P/N but I do remember it calling out a specific version.
Old Oct 27, 2012 | 10:02 AM
Here's the BT Module label on my 2005 showing the P/N:
You would also need an Interlink Cable.
Old Oct 27, 2012 | 10:37 AM
ccfulton's Avatar
Wow, removing the rear seat just to take a picture for a fellow member, now that is dedication!
Old Oct 27, 2012 | 10:57 AM
Charlie,
I left it 30 minutes thinking that's what you'd gone out to do but you just didn't step up - what else could I do?
Old Oct 27, 2012 | 11:38 AM
ccfulton's Avatar
You're right, I'm just not keeping up my end!
It is a poor excuse, I know, but I've gotten myself distracted with writing up the installation of a water methanol system and have lost sight of priorities.
Old Oct 28, 2012 | 11:57 AM
Default Phone
Thanks everybody for the info. I hadn't been considering it before. But now am thinking maybe it would be a good idea to hook up my Blackberry to the Jag. Out of my depth I'm sure, but if the 2002 had any kind of BT module somebody ought to be able to figure it out.
Old Oct 28, 2012 | 12:04 PM
WhiteXKR's Avatar
I do not think that the 2002 had factory Bluetooth.
I have attached my writeup on adding aftermarket Bluetooth.
Jagzzz
Aug 8, 2021 02:45 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Wayne Enticott
Sep 29, 2015 08:55 AM
mikin
Sep 26, 2015 10:21 AM
