Pollen filter
Old Apr 8, 2009 | 03:06 PM
moose's Avatar
Default Pollen filter
Can someone tell me where the cabin air filter is located on a 2005 XKR and how to change it. Have changed many filters on other cars, I can't find this one.
Old Apr 9, 2009 | 08:45 AM
test point's Avatar
The filter, if fitted, is below the cowl panel grill. Wiper arms have to be removed along with the grill. The filter should be visable at that point. Many of the earlier US cars did not have the filter. I do not know about the '05 MY.
Old Mar 21, 2010 | 06:28 PM
OregonJag's Avatar
Question
Well..rats. After buying a replacement filter before exploring the cowl I find my '97 has no filter housing or mount or whatever. Now that I have a cabin air filter with no place to go, anyone ever retro fit the parts? If it goes in through the cowl opening it looks like the pax side wiper spindle would need to come out and maybe part of the bracing.
Mike
Old Mar 22, 2010 | 12:42 AM
GreenJewel's Avatar
Mike
Here is some information that I received when asking about this filter. "Also you need part MJA6865AA “Filter element Housing” , and of course the filter MJD6863AA".
Hope it helps.
Mark
Old Mar 22, 2010 | 03:03 AM
avos's Avatar
In addition you also need to enable the "pollen Filter" setting in the car with the dealer tool (IDS/WDS), this will ensure the fans blow a little faster to overcome the extra resistance of the filter.
Old Mar 22, 2010 | 12:21 PM
H20boy's Avatar
Sorry we didn't get to you sooner. I was told awhile back from a dealer source, that this 'pollen' filter housing was an add-on that never got added to the car after awhile. Very few ever made it out of the factory with one.
Old Mar 22, 2010 | 12:22 PM
H20boy's Avatar
Oh, and you're not the only one to buy a filter, to discover they don't have the housing for it. Someone else did also, then offered me the filter. I checked, turns out mine didn't have it either. I think this member STILL has the filter to this day.
Old Mar 22, 2010 | 03:22 PM
Brian2000XKR's Avatar
That's pretty funny, as I too have Pollen Filter sitting in my garage................ with no framework to set it into. Maybe I'll get around to it someday, but it's a low priority for sure.
Brian
Old Mar 22, 2010 | 04:26 PM
OregonJag's Avatar
Lightbulb
..maybe we should put in for a group purchase... P-)
Old Mar 22, 2010 | 04:29 PM
H20boy's Avatar
unless you're super-duper-sensitive allergic!
Old Mar 22, 2010 | 06:23 PM
moose's Avatar
Default XKR cabin filter
I'm the one who started this. I bought the filter before I removed the cowel and discovered that the car was not fitted with one. Fortunately, I was able to return it. I would be good to remove the page from the owner's manual if it doesn't exist.
Old Mar 23, 2010 | 03:16 AM
Camgear's Avatar
It does state in the 'book' that some items are extras. A main dealer can give you a print off of extras fitted. I found this out when my wing mirrors would not fold back. They're extras !!
George
Old Mar 23, 2010 | 05:03 PM
hlgeorge's Avatar
I too have the filter in my "Jaguar parts bin" !!
Old Mar 23, 2010 | 07:03 PM
lah024's Avatar
Default does a s type have one?
Old Mar 24, 2010 | 12:20 PM
stevepaa's Avatar
I installed the housing and added the filter. You can send those extra filters my way
Old Mar 24, 2010 | 02:16 PM
Brutal's Avatar
Stype, xj 04^, xk 07 ^ and even the lowly xtype has them, and the new xf
Old Mar 24, 2010 | 07:08 PM
OregonJag's Avatar
Exclamation
Whoa, now we're gettin' somewhere.. how about a blow by blow of the retrofit?
What did you have to disassemble to install the housing?
Mike
Old Mar 25, 2010 | 11:04 AM
stevepaa's Avatar
remove the wipers
http://www.captainjaguarscathouse.co...F_3/3_C_09.tif
remove the caps(2) on the plenum assembly (1) and remove screws(3) and remove (1)
http://www.captainjaguarscathouse.co...F_3/3_G_05.tif
remove struts (1)
http://www.captainjaguarscathouse.co...F_3/1_O_04.tif
you may need to move wiper motor to facilitate install
I also replaced the closing plate(8), you may want to move it out of the way to enable install.
http://www.captainjaguarscathouse.co...F_3/1_N_07.tif
install all parts
reassemble.
Old Mar 25, 2010 | 11:14 AM
stevepaa's Avatar
hum, why isn't there an edit button?
on N07 you install parts 1, 2,and 3,
Old Mar 25, 2010 | 02:57 PM
OregonJag's Avatar
Thanks Steve
