Poly Bushings
Old Jan 19, 2012 | 08:15 PM
Goldlion's Avatar
Default Poly Bushings
Has anyone installed PowerFlex or other poly bushings on the rear a-frame and rear sway bar links of their XK8\R and if so how have they performed?
Old Jan 20, 2012 | 03:01 AM
Where have you found a supplier of poly bushes for the rear A-frame?
I've seen them for the front upper wishbone but can only find OE for the A-frame.
Old Jan 20, 2012 | 07:31 AM
Jaxkr's Avatar
I purchased my poly bushings thru Kevin @ Design XKR. He should be able to supply you with a complete vehicle set.
Old Jan 20, 2012 | 07:51 AM
Thanks - I've bookmarked the site for future reference.
Design XKR
HTML coding skills leave a bit to be desired but the product range looks good.
Old Jan 20, 2012 | 09:49 AM
XKRacer's Avatar
I am a Powerflex dealer..... fitted a complete set just the other day
Old Jan 20, 2012 | 10:47 AM
It's the only photo on your website that's the size of a postage stamp!
Easier or harder to fit than OE? Have you had any customer sets out there long enough to compare how well they last?
Old Jan 20, 2012 | 11:20 AM
XKRacer's Avatar
There's not exactly a lot to show, I would say easier to fit tah original, the rear main frame mounts require a good fly press or similar and a way to hold it level whilst you push them out and in again.
If you click on the picture on my website it will take you to the Powerflex XK section which lists all the bushes with prices of which I give a 20% discount to UK customers.
Its quite a job to do the lot in one go, a ramp is escential to do it safely
Old Jan 20, 2012 | 11:42 AM
.............If you click on the picture on my website it will take you to the Powerflex XK section...................
Link is broken - the 'Contact Us' link works but the photo has no link.
Old Jan 20, 2012 | 01:24 PM
Goldlion's Avatar
My main question is how well do the PowerFlex poly bushings perform on the rear frame and sway bar links. Do they noticeably improve the handling without degrading the ride too much? I have the PowerFlex bushings on the front top control arm and they have been excllent. Im looking for the same effect in back.
Old Jan 20, 2012 | 01:59 PM
Jaxkr's Avatar
I have had them in the back of my car for app 3 years & had no issues. They will definetly make an improvement to the ride & handling.
Old Jan 20, 2012 | 05:33 PM
........ I have the PowerFlex bushings on the front top control arm and they have been excllent.
How long / how many miles have you had the front bushes fitted?
Old Jan 20, 2012 | 08:37 PM
Goldlion's Avatar
I have had the PowerFlex poly bushings on the front top control arms for about 10 months/5000 miles. I did not install them on the bottom control arms because I was concerned ride quality might suffer, potentially too much road shock/noise might be communicated to the steering wheel/cabin. The PowerFlex bushings are very well made and quite superior to the OEM bushes and should last much longer.
Old Jan 21, 2012 | 03:32 AM
XKRacer's Avatar
Works perfectly for me...... ?
CLICK HERE and this will take you to the same thing
Old Jan 21, 2012 | 04:02 AM
Aaaggghhh! - that's some colour scheme
I've never been a fan of the OEM upper wishbone bushes and had a five day marathon removing the passenger side bolt from my last XK8. If I'd known about Powerflex then, I'd have used them for the rebuild instead of going with the Jaguar ones again.
Goldlion has given his upper wishbone Powerflex a good workout and sounds very happy with them so I'll be contacting you for a set when the weather improves.
TreVoRTasmin
Feb 23, 2021 03:13 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
Dave1109971
Oct 2, 2015 06:11 PM
