Power Steering Fluid ?
Old Feb 20, 2012 | 10:54 AM
Jon89's Avatar
Default Power Steering Fluid ?
My 2006 XK8 owners manual specifies Dexron IIE. Has that been superceded by Dexron III? Dexron IIE seems to have gone the way of the dinosaurs....
When turning our steering wheel at speed, it sometimes coos very softly like a dove. Our S-Type did the same thing a couple of years ago, and a $9 magic liquid additive from Jaguar specified in a TSB and poured into the power steering fluid tank quieted the steering wheel to tomb-like silence once again. But my TSB paperwork from that time lists only the XJ, S-Type, and X models. No mention of the XK models for this particular fix. Have any XK users had this problem and fixed it with the magic additive?
Old Feb 20, 2012 | 02:06 PM
oldmots's Avatar
I use Mobil 1 synthetic ATF. I just suck out what's in there at every oil change and refill with the Mobil 1. I have no problems with noise.
Old Feb 20, 2012 | 02:29 PM
WhiteXKR's Avatar
My S had also experienced the infamous steering noise, but I have never heard of the problem on the XK.
Old Feb 20, 2012 | 07:29 PM
Mexk8's Avatar
The only problem I've had with mine is that all the fluid came out all over the floor yesterday. Seems the hose had broken. Should have it fixed by tomorrow says "el mechanico"....
Old May 10, 2012 | 01:55 AM
Silverback Jag's Avatar
How do you get to the steering wheel build tank?
Old May 10, 2012 | 05:38 AM
I usually understand different US and UK part names but 'steering wheel build tank' has me completely lost...........
Old May 11, 2012 | 02:54 AM
plums's Avatar
Don't feel bad, it's not a North American term either.
Old May 11, 2012 | 03:41 AM
steveinfrance's Avatar
Isn't it that space under the spare wheel where you pour epoxy resin to cast an emergency replacement steering wheel?
sogood
Sep 15, 2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
