Problem with Hawk HPS pads
Old Apr 17, 2013 | 03:34 PM
stevepaa's Avatar
Default Problem with Hawk HPS pads
I bought some HAWK HPS pads for my standard 2001 XK8.
When trying to fit them I ran into a problem. I pushed the main pad into its position atop the piston, and fitted the other side and the pushed the caliber around the rotor. I could not get the guide pins to install. I could not push the caliper body far enough into position.
Looking at the HAWK pads the circlip on the back of the pads which hold the pad into the piston are incorrectly placed. It is about 1/8" off from where it should be. It is 1/8" nearer the round notched edge thereby pushing the pad 1/8" away from caliper body and thereby not permitting the guide pin installation.
Still waiting for HAWK to get back to me.
Attached Thumbnails Problem with Hawk HPS pads-pads1.jpg   Problem with Hawk HPS pads-pads2.jpg
Old Apr 17, 2013 | 06:22 PM
dannyS's Avatar
Hi there, Stevepaa.
I am not going to really help you with your issue except the fact that I purchased the Hawk Performance HPS Brake Pads HB135F.770 pads for my front application, and never got them fit properly. They are simply too wide for the stock caliper . What makes this problem even worse is the fact that my rotors were much thinner than their original condition and the pads were still about 1/16" or more thicker.
I am actually selling them on eBay as we speak. Chose Posiquiet Ceramic and could not be happier.
Here are some :
Here is the scale : width
Hope you'll make it work unlike me. Even local mechanic said to drop the performance fever this time
Good Luck, mate!
Old Apr 17, 2013 | 07:17 PM
plums's Avatar
Worse yet, take a look at the rivet holding the clip. It looks like they gave some pins to a kid with a hammer and said "go to town".
Old Apr 17, 2013 | 09:38 PM
stevepaa's Avatar
The HAWK pads I have are HB135F.642
.642 thickness. .770 thickness would not fit as you confirmed.
Old Apr 17, 2013 | 10:06 PM
dannyS's Avatar
Good point, mate. My bad for being overly trustful in vehicle compatibility charts
Old Apr 24, 2013 | 09:56 AM
stevepaa's Avatar
HAWK provided feedback that I am disappointed in. They buy the backing plates with the clips installed and then add their composition material. I suggested that measurements be made to confirm the clips are positioned correctly. HAWK response was since these pads fit several other cars with no issues,they have decided that listing these pads for use on my XK8 was in error.
The pads fit my 2000 XK8 but not my 2001 XK8.
So I called PFC. They confirmed that they have the same issue. Their pads fit 97-2000 but not 2001 on.
But Jaguar does not show any change in pads or caliper for the 2001 from 2000.
As I was looking for other pads I noticed that Amazon still says that Danny's thick pads should fit. Amazon also says the HAWK pads I have should fit my car.
Anyone use akebono on 2001 xk8 and have a part number?
Old Apr 24, 2013 | 11:01 AM
Dennis07's Avatar
Steve,
The Akebono part # I have is ... AK5 EUR394A. Front pads.
This is from something like five years ago though, so probably worth double-checking with the manufacturer.
Could not be happier with them, BTW. No dust!
Old Apr 24, 2013 | 11:19 AM
p-Rock's Avatar
Where are people getting the word to purchase HAWK pads? I guess I can blame it on using worldPAC for brakes and why I've never heard of them.
Akebono, Akebono, Akebono
Old Apr 24, 2013 | 11:39 AM
stevepaa's Avatar
HAWKs are recommended on some Porsche forums.
They were great on my 2000.
Old Apr 28, 2013 | 08:35 AM
Cyqb XK8's Avatar
We, ALCO Brakes list D394-7395 wich is .642 thick. There is also D394A-7284 which is .770 thick and won't fit. make sure to get the linning number 7395.
Old Apr 28, 2013 | 04:00 PM
mike66's Avatar
P-rock and Dennis, have to throw my hat in with akebono, used them on all my cars and they're awesome and no dust. Disclaimer-I have not tested these under overly spirited conditions, but probably others have.
Old Apr 29, 2013 | 07:20 AM
p-Rock's Avatar
I've mashed Akebono's EURO's and ProACT's (different car for the ProACT's) so hard you'd think they'd split in half. It's almost as the pads have a brain and know when you need to stop like a race car
Old Apr 29, 2013 | 03:10 PM
govatos's Avatar
Hawk ceramics work great on my '06 XKR
Old May 3, 2013 | 11:35 PM
stevepaa's Avatar
The dealer I got them from opened a box of Bosch pads and they have the same issue. I went on line and found a picture of Jurid pads which look correct.
click on pic
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
cissdm
May 3, 2016 06:02 AM
EZDriver
Sep 8, 2015 09:25 AM
JagLove86
Sep 6, 2015 10:36 PM
