Question on OBDII SCANNER
Old Jul 19, 2011 | 03:28 AM
porkenstein's Avatar
Default Question on OBDII SCANNER
I know that the cheaper scanners don't read faults with the abs and some of the other systems. My question is will they reset the faults even though they don't read them. Can't really afford to spend allot on a scanner.
Old Jul 19, 2011 | 08:31 AM
cohibarandy's Avatar
Pork: I believe I bought mine at O'Reilly's auto supply 8 years ago for about $200. It reads the jag codes, and clears the faults, and I haven't even updated the software. So, you should be able to find one easily.
Old Jul 19, 2011 | 08:36 AM
Gus's Avatar
Gus
Take a look at this OBD list and see what it has to offer then post your question OBDII Code Scanners ** Member Approved ** - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jul 19, 2011 | 01:52 PM
I have looked at the list many times in the past and spent may hours searching for the answers. I don't just post without looking. It is on the list but same question. It will read lots of the faults but not all of them. Its on the list but as mentioned in the forum in other places you have to spend 500 to get one that does everything. SO my original question is legitimate. Even though it won't do everything such as abs will it clear all faults including abs faults.
Old Jul 19, 2011 | 02:31 PM
Gus's Avatar
Gus
I would think that any OBD reader that can see the code should be able to clear the code. For me a reader to see all the codes I want will cost $500+ a reader for just “P” codes is around $35 to $200. If I need ABS codes I can go to my local garage who has the equipment to read “C” & “B” & “U” codes and pay him a few dollars to pull and clear the codes.
Old Jul 19, 2011 | 03:36 PM
Beav's Avatar
If you have an old XP laptop you can watch for a used VCM on eBay (not a Chinese knock-off.) Then buy IDS software for ~$50 on eBay. That way you'll have what the dealer uses. Down side is it won't work with every other car, like an aftermarket scanner, but it will be 'native'.
Old Jul 19, 2011 | 05:13 PM
Thanks Beav for that info. I will take a look but I just went out to go somewhere and magically the fault I had last night, abs and stability control is gone without doing anything. Didn't think those faults would reset themselves. I did order a hand held scantool. Something I have always wanted anyway.
Old Jul 19, 2011 | 06:04 PM
Jen & Neil's Avatar
Ok, got a snap on modis at work, it will do OBDII global for my 98 XK8, is getting a VCM (and that would be what?) a better idea, and running an old XP laptop!... Thanks in advance
Old Jul 19, 2011 | 09:34 PM
Beav's Avatar
Type VCM into an eBay search box and you'll see a couple dozen - usually. Native is always better than global, no matter what brand. Whether or not it's $500 or so better is a matter of opinion. The VCM basically acts as a translator between the vehicle and the laptop and is Ford's native tool.
Bcrary3
Sep 12, 2021 05:41 AM
philwarner
25
Jun 26, 2021 05:43 AM
scooternva
19
Oct 27, 2015 02:14 PM
RoyLittle0
Sep 17, 2015 01:05 PM
DustysSon
Sep 13, 2015 04:17 AM
