Radio/Climate Bezel Surround
Old Oct 20, 2025 | 11:19 AM
AbnMike's Avatar
Default Radio/Climate Bezel Surround
Mine's cracked in multiple places and in my journey to replace everything possible on my xk8 I want to get a new one.
This one is on ebay
I want to confirm that it will fit a 1999. It's listed as a 1997 and the description says 1997 - 2006, but looking to the experts to see if it will work in a 99 or if they made changes.
Old Oct 20, 2025 | 02:50 PM
bladerunner919's Avatar
There are two types, as the radio changed, and they are different shapes - I suspect that is not correct for your car.
Old Oct 20, 2025 | 02:57 PM
michaelh's Avatar
Possibly not. The header unit in the '97 has a somewhat different control layout to '98-on, and appears to have a more pronounced 'lip' at the bottom of the panel.
The EPC shows a VIN break from LJA6318AB to LJB6318AB (via LJB6318AA) @ 018108, which is the start of the MY98 cars.
Heritage shows both these numbers as current.
Possibly worth a try if you have the option to return the part if it doesn't match your header unit profile?
Sorry for being a bit vague, but the Jaguar info I've found isn't definitive.
Old Oct 21, 2025 | 03:28 AM
The obvious question is whether or not it looks the same as the one you have? The two types are noticeably different around the radio.
Old Oct 21, 2025 | 06:50 AM
JaagXKR's Avatar
It doesn't fit, the Ebay's one is for the early radio models, like this:
Old Oct 27, 2025 | 05:47 AM
galearmstrong's Avatar
My 99 XK8 radio Bezel is LJB 6318 AA
trebor2468
Nov 5, 2025 11:08 AM
Daglover
Aug 22, 2025 08:46 AM
brobin
Jun 22, 2021 12:20 PM
peekaboo
Oct 16, 2014 07:54 AM
egreig
Oct 21, 2012 04:11 AM
