Radio DIN size
Old Apr 12, 2017 | 10:32 AM
YYC guy's Avatar
Default Radio DIN size
Does anyone know if the standard XK100 radio can be replaced with a double Din unit?
Old Apr 12, 2017 | 10:56 AM
rothwell's Avatar
Not easily. Technically it is a single. There have been a few attempts but all required some custom work to the console button layouts.
Search the threads if you want to see specifics.
Old Apr 12, 2017 | 11:57 AM
Ungn's Avatar
Double Din, No. Using XJ8 faceplate and filler, single DIN is easy.
Old Apr 12, 2017 | 06:06 PM
YYC guy's Avatar
Thanks guys, does either of you know where to find the correct facia plate?
Old Apr 12, 2017 | 06:40 PM
dsd's Avatar
dsd
What year is your car?
Face plate parts for 1DIN are in the sticky howto and my stereo thread.
Old Apr 12, 2017 | 06:51 PM
dsd's Avatar
dsd
Jaguar part LJA6318AB converts the mounting plate to a 1DIN.
Nexxis sells an external trim piece (xj6) that fills the gap.
PAC has a steering wheel control interface.
Here is my thread:
https://www.jaguarforums.com/forum/x...yansit-168864/
Old Apr 12, 2017 | 07:23 PM
Ungn's Avatar
I got mine from a '96 XJ6 in the junkyard.
Old Apr 13, 2017 | 05:26 PM
YYC guy's Avatar
Thanks all,
This is why I love this forum, so much knowledge out there.
Old Apr 14, 2017 | 08:53 AM
Ronald12845's Avatar
My 2003 XK8 radio has been replaced with a Pioneer unit and I'd like to find an original.
Will LJD4100AA or another OEM fit? Jaguar Parts list says LJD4100AB.
Old Apr 14, 2017 | 10:35 AM
dsd's Avatar
dsd
Do you have premium sound with navigation? Do you still have the nav system in rear?
Old Apr 14, 2017 | 10:52 AM
Radio/CD replacement.
It had premium sound but no Nav unit. The original radio is replaced with a Pioneer DEHX9500BHS and the original amp has been replaced with 2 Prime R150x2 amps. It sounds awesome but I would like an original in case a future buyer balks.
Old Apr 14, 2017 | 10:55 AM
It had a trunk mounted CD but that's gone also.
Old Apr 14, 2017 | 11:02 AM
dsd's Avatar
dsd
I think the AA part number should be fine. I suspect any non-1997 radio would ok. Make sure you get the code or note serial number.
Old Apr 14, 2017 | 01:45 PM
bobhoff's Avatar
I found radio for 2003 XK8 using Parts on Line.com
https://www.partshotlines.com/
Old Apr 14, 2017 | 03:11 PM
Thanks for your help. This is a great site.
PbJag
19
Aug 31, 2018 01:07 AM
