Rattle (paper flapping noise) under hood
Old Apr 13, 2013 | 06:46 PM
Shouldbeworkin's Avatar
Default Rattle (paper flapping noise) under hood
I've got one that's stumping me. About a week ago I started up the car and as the AC kicked on it sounded like a piece of paper was rattling in the duct work. When I turned off the air, the noise seemed to go away. I was surprised when I popped the hood that turning off the HVAC didn't actually stop the noise, it just kept it from entering the passenger compartment. Even with the hood open, it sounds like a piece of paper rapidly flapping in a breeze (perhaps actually a thin metal rattling). Looking under the hood from top and bottom, and can't find a cause or sure source - it sounds like it's coming from the center of the hood / engine, but it's hard to tell. I pulled the air intake and filter and they're both clear.
Anyone run across this or have a suggested next step?
Old Apr 13, 2013 | 08:03 PM
Jag#4's Avatar
Another chapter in "find that noise".
Look around the drive belt and make sure nothing is amiss there.
I know it sounds like it's coming from the top middle of the engine, but check underneath the car. I had a sound last week that made me think the primary chains we about to come off and lunch the motor. Turns out it was a small tree limb stuck in the exhaust under the driver's position. Still not sure why that sounded so metallic.
Old Apr 14, 2013 | 07:33 AM
Dennis07's Avatar
Does the sound seem to vary with the engine RPMs ?
Old Apr 14, 2013 | 10:22 AM
Is the noise there both when stationary and when moving?
If it's only there when you're moving, check the Undertray (item 6) is securely attached:
It's held on with 'scrivets' (plastic rivets) and oscillates making a strange noise if some of these are missing or broken.
Old Apr 15, 2013 | 10:35 PM
Thanks for the great suggestions. Based on the advice I went out to the garage to dig around and continue my hunt. I was surprised to find the rattle had mysteriously disappeared. For now I'm filling this one under "It's better to be lucky than good."
Old Apr 16, 2013 | 05:47 AM
Frog's Avatar
I had a 'paper flapping noise' on my Transit van and it turned out to be the windscreen wipers lifting off the screen at high speed.
XJ8JR
26
Aug 8, 2020 09:38 PM
Razor
Aug 28, 2019 08:34 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Horus
Sep 18, 2015 05:39 AM
1100me
Sep 7, 2015 06:26 AM
