rattle/tapping in rear end
Old Aug 29, 2016 | 11:44 AM
brgjag's Avatar
Default rattle/tapping in rear end
03 XK8
I have had my Jag in to the same repair shop two diff times. I have a metal tapping/rattling sound from what appears the left rear end. It sorta sounds like someone has a small metal ball in a tube and they are shaking it up and down. The shop tried new rear sway bar bushing, no diff. They say they can not figure what it is when up on the rack. Could it be something in the shock? Could it be the top mount and they can't tell? The rear end is sitting properly so the shock seems to be fine. Is there some structure up under there that could be loose or broken? This is a rust free car that has never been wreck as far as we can tell.
The noise drives me nuts. Unless the radio is up or the top is down you hear it over the smallest of bumps in the road.
Old Aug 29, 2016 | 12:27 PM
RaceDiagnostics's Avatar
I had something similar before and after my rear end rebuild, I think t is the shock itself.
Old Aug 29, 2016 | 12:34 PM
brgjag's Avatar
That is what they told me the first time they looked at it. Something in shock is broken.
Old Aug 29, 2016 | 04:04 PM
Matthew Chidester's Avatar
This might not be a whole lot of help.. but I had a rattle going on in the rear quarter and I noticed the rear reinforcement bar bracket that is attached via a rivet was rattling.. I stuck a small spacer behind the bracket and the noise is gone.
Another noise problem on another car.. over bumps I was hearing some loud clanking noise especially over a speed bump and when I put the car in the air the mechanics couldn't find it. Turned out much later it was the brake pads and some brake pad lubrication and a check on the hardware fixed that..
Hopefully you can find it :/ I know that can drive me nuts..
Old Aug 29, 2016 | 07:07 PM
Anthony8858's Avatar
My money is on the rear....
Shock mount plates
Upper shock bushings (they come along with new shocks), and are known to deteriorate.
Or the shock itself.
If you haven't changed the shocks, now is a good time.
Old Aug 29, 2016 | 07:29 PM
brgjag's Avatar
yea more money into the old girl
Shock mount plates
Old Aug 29, 2016 | 07:31 PM
silverXKR03's Avatar
Check the exhaust mount. I had the same problem couldn't figure it out until I was replacing rear shock bushings and noticed a slight gap between the rear rubber exhaust mount and the metal hanger/ rod running through it. I took the hanger out the mount rapped the rod in electrical tape and put it back in, problem solved.
Old Aug 29, 2016 | 08:01 PM
Gus's Avatar
Gus
I would find a shop that has a wireless noise devices and have them test the car with them attached. I have used them twice and it took me to the problem.
Old Aug 29, 2016 | 09:33 PM
Ungn's Avatar
Shock top mount on my car. Poly foam crumbled and the upper shock washer hit the top of the mount during extension.
I have a coupe so its probably louder. It was more of a banging or clunking than a rattle.
As Anthony said, new shocks. Replace the spring cup foam while you are in there and you are good for another 10 years.
Old Aug 30, 2016 | 04:25 AM
toaster's Avatar
Sometimes its only a slack parking brake rope.................................
Old Aug 30, 2016 | 08:51 AM
motorcarman's Avatar
Tap the handbrake cable near the diff and see if that is the noise. A few turns on the adjusting nut and it should stop.
bob
Old Aug 30, 2016 | 12:04 PM
Jon89's Avatar
My wife reported the same metallic rattling sound driving her nuts in her 2006 XK8 throughout the summer of 2014. Speed didn't matter - if the car was moving, the rear end rattled. The only time she couldn't hear it was when the ragtop was down. Turned out to be an internal valve inside the left rear shock. They tend to break off and rattle around after a few years, yet the shock continues to perform normally. New rear shocks in October 2014 resolved the issue. Good luck with yours....
Old Aug 30, 2016 | 02:22 PM
brgjag's Avatar
This is what I am going with. Just no money in budget for this car right now so it will just have to rattle away.
coldpad1
May 6, 2021 03:40 PM
sunchip
Apr 3, 2016 09:06 PM
iownme
Apr 1, 2016 05:20 AM
dsnyder586
Mar 30, 2016 09:47 AM
LnrB
Mar 25, 2016 09:13 PM
