Readiness and the drive cycle
Old Jan 13, 2016 | 04:45 AM
  #61
JagV8's Avatar
The snag - on rare occasions but they happen - is a kind of Catch-22 where the monitors were cleared then can't set due to some fault that in turn can't be flagged due to not enough set monitors. (Ideally you'd never clear codes and never disconnect the battery (or have a flat one) so this Catch-22 could not happen.) The logic inside the PCM is horrifyingly complex and only mostly works when faults are present!
Old Jan 13, 2016 | 10:10 AM
  #62
64vette's Avatar
Interesting, seems as that might give a clue as to why many of us get stuck in the "incomplete" status . I was surprised that my faulty purge valve with a short (failed diode or winding?) did not show a fault code, yet when I unplugged it a fault code popped up (purge valve circuit open). I would think that if a component can fail in two simple ways (open or short) that both should throw a code.
Old Jan 14, 2016 | 01:41 AM
  #63
JagV8's Avatar
Normally will. I guess you had yet another fail. Not been reported before, apparently, so "lucky" you.
Old Sep 29, 2016 | 10:37 PM
  #64
johnhennessy's Avatar
i wish volkswagen had programmed jaguar ECMs
Old Sep 30, 2016 | 02:12 AM
  #65
JagV8's Avatar
I don't think jag would have wanted the fines / buy back all the cars.
Old Sep 30, 2016 | 11:25 AM
  #66
hirev's Avatar
i have the same issue, cannot pass smog in ca. cannot get the car to reset itself, new battery and other work 200 miles ago and will not pass smog...so i will just keep driving, that's all i can do. it's somewhat comforting to see others have had this same frustrating problem and eventuallly the car just resets itself.
Old Oct 1, 2016 | 01:43 AM
  #67
JagV8's Avatar
Use OBD live data. See what's happening.
Old Oct 1, 2016 | 01:59 AM
  #68
hirev's Avatar
What model make of scanner is available
The one I bought does not talk to jaguar
Works on BMW and Honda
dsnyder586
Dec 29, 2024 07:39 PM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
JimMLiny
Sep 9, 2015 08:13 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
