Rear 1/4 windows will not raise
Old Nov 15, 2014 | 10:26 AM
revitup's Avatar
Default Rear 1/4 windows will not raise
Hello I am sure this topic has been covered many times so perhaps some one can direct me to the right link. I am operating the top by hand (leaks + bad pump) and both window stayed down. I have raised the driver side by flashing the relay in trunk but this will not work on Pass side. I have in mind to fir a bypass switch but its chilly now and I would appreciate a quick fix. I wonder what would happen if I disconnected the wires to the micro switches on this piston.
Thanks in anticipation
Old Nov 15, 2014 | 10:27 AM
revitup's Avatar
Sorry I forgot to mention year is 2001 us model LHD
Old Nov 15, 2014 | 11:28 AM
WhiteXKR's Avatar
See https://www.jaguarforums.com/forum/x...-closed-71304/
There are separate fours separate relays...make sure you are bypassing the correct ones.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
