Rear light cluster 1997 XK8
Old Oct 14, 2009 | 09:59 AM
Hey Sheridan, I've seen similar issues on other vehicles wherby one of the bulbs is actually gone which triggers the double flash rate... I assume you've checked that?
In the meantime I'm moving this to general tech help where it should#ve been posted....You're far more likely to get help there than in the forum help section.
I'm sure Thermo or one of the techs will be able to give you the definitive answer soon
Good luck
Old Oct 22, 2009 | 02:05 PM
daddyo007's Avatar
Mine did this on my 99 xk8 coupe forever. But after several bulbs the dealer said that they have had problems with grounding. They installed a secondary ground on both tailight assemblies. All it amounted to was adding a 16 ga wire with a closed loop on both ends. The wire is about 8" long and one end is on the metal of the tail light assembly the other end was attached to screw stud near the assembly. I have been troulbe free for about 5+ years.
Old Oct 22, 2009 | 02:24 PM
Brutal's Avatar
damn beat me too it, DO IT its your problem
Old Jun 26, 2014 | 11:46 AM
XK8Wayne's Avatar
I have this same problem. I will give the additional grounding a try. Thanks.
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
jdzubas
Oct 4, 2015 09:14 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
