Rear Lights not working & Hello!
Old Apr 22, 2010 | 06:44 PM
hlgeorge's Avatar
Originally Posted by Gus
Did we ever find the problem?
I don't think he has found the module yet.
Old Apr 22, 2010 | 07:29 PM
Gus's Avatar
Gus
I would say it is under the fuses and relays.
Old Apr 23, 2010 | 03:58 AM
JagSpain's Avatar
I cant find it, had a look under the fuses and modules but nothing.... No one knows exactly where it is?
Old Apr 23, 2010 | 07:46 AM
Gus's Avatar
Gus
It looks like it is in the area near the right rear light, hyd pump, c/d changer
Old Apr 26, 2010 | 04:10 AM
JagSpain's Avatar
Under the fusebox was the locking & security module at the rear of the trunk was the adaptive control module, above the cd-changer in the trunk is another module but judging by the connectors isnt the lamp control module, since in the 2001 diagram there appears to be no Lamp control module I can only assume that it is as in the 2001 model and has only the SLCM (Security and Locking Control Module), next question is whether its something that can be easily reset by Jaguar or could it be a wiring issue?
Old Nov 26, 2011 | 02:52 PM
john henderson's Avatar
my tail lights arent working, the module to the rear of the fuses which are behind the battery had a burned area. regrounding the light ***'ys is advised.
Old Mar 30, 2012 | 07:28 PM
blousehouse's Avatar
Default rear lights not working here either
Hi All, I have the same problem with my 2000 XJ8 just this week. The "rear Lights" warning sign came on & I had my son check..a brake light was out..put that in and next time I checked and found only the break light is working. The other 3 lights in the same panel are not working. I assume these are the running light, fog lights (yellow) & backup.
I've checked fuses & relays and all are working.
I don't see that the previous owner was able to find a solution. Did I miss a post? I would appreciate any help you have on this. Thanks
Old Apr 1, 2012 | 09:37 AM
  #28
rear light module likely burned. mine was caused by 45 watt bulbs in the 7 watt rear driving light sockets.i ran grounds from tail light metal backing plate to body also. find problem or next module will burn too!
Old Apr 1, 2012 | 09:40 AM
the module is a little bigger than a pack of cigarettes. it is to the rear of the battery.
Old Apr 4, 2012 | 04:08 PM
  #30
I really appreciate your help on this. I think I found the module, behind the battery. When I take the black cover off I see 4 posts w/bolts and what looks like 2 fuses marked 250A..? As we're playing musical cars I won't have much time until the weekend to search further. I appreciate any help.
Old Apr 4, 2012 | 06:13 PM
  #31
WhiteXKR's Avatar
This is the XK8 forum...you should to go to the XJ8 forum for the best help.
And those 250 Amp power mains fuses are not what you are looking for.
Old Apr 12, 2012 | 02:27 PM
  #32
my tail lights didnt work. the lamp control module(in fuse box to the rear of the battery-it has a yellow lever-lock plug attached to it) had a few burned ?resistors. you can see and smell them. did the novice thing and put a new module in-it burned up too. THEN i discovered the forum. i checked the grounding tabs-looked pristine. i think the seller replaced them as everything looked new. i grounded the backing plate to the nearest bolt to be sure.on final check i found 45 watt bulbs where the 7 watt tail lights should be-same size socket. installed new bulbs and module- so good. interestingly no dash warning light comes on with the module burned. hope this helps
Old Apr 13, 2012 | 01:50 PM
  #33
Smile 2000 XJ8 tail lights out
Hi John,
Thank you for all your help. It turned out that my left brake bulb needed replacement as that bulb has 2 filaments, 1 for the brake which was working & 1 for the tail lights, which was broken. As soon as I replaced that my tail lights were good to go. Glad it wasn't anything more serious.
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
johnnie ryall
Oct 19, 2015 09:44 PM
tony bosco
Sep 1, 2015 02:06 PM
tonydbaker
Aug 30, 2015 11:02 PM
