Rear quarter window regulator cable diagram.
Old May 14, 2020 | 10:07 AM
Oldelance's Avatar
Default Rear quarter window regulator cable diagram.
I have taken the rear quarter window regulators out of my 2004 xk8 due to the cables slipping off the pulleys. I can't figure out how to retread the new cables. Can someone please help me with a diagram or instructions. Also will the complete assembly go back in from the window access hole.
Old May 14, 2020 | 11:46 AM
rothwell's Avatar
Here is my DIY with some pics. Took me a while to figure it out. Hope it helps.
Glad you are using new cables. They are cheap on Amazon and come with a new plastic spring holder that I highly recommend you use too.
I was able to put the regulator back in from the top but I did have to disconnect the convertible top mounting to get enough room to pass through.
JackJohn
May 2, 2018 12:33 PM
Lannyl81
Aug 29, 2014 09:13 PM
Max
Mar 3, 2013 03:37 PM
drisean
Aug 16, 2009 02:49 PM
perezrp101
May 22, 2009 12:29 PM
