rear subframe removal
Old Aug 7, 2024 | 03:03 PM
wymjym's Avatar
Default rear subframe removal
Hi,
I have a leaking dif front seal that needs replacing.
I have my car up in the air, 24" and have removed all the neceassary fastenes except the remaining front subframe ones.
I'm handling this repair myself and am wondering if I can 'semi' safely drop this rear suspension assembly by myself with a 2 ton jack (or two)?
wj
Old Aug 7, 2024 | 04:31 PM
PKWise's Avatar
I did the same as you and discovered that the Diff assembly is really heavy and awkward to find centre of gravity with a trolley jack. It just wasn't safe enough to continue as a one person job. In the end I reduced the mass by partly stripping the assembly and used a Motorcycle lift to lower the whole lot and also to lift it back in. Much safer this way and I also used wooden planks to chock each stage and keep it balanced.
Old Aug 7, 2024 | 06:03 PM
wymjym's Avatar
Do you think two people, two floor Jack's with transmisson adapters would work?
Or any other suggestions short of stripping it further.
Wj
Old Aug 8, 2024 | 01:35 AM
baxtor's Avatar
Originally Posted by wymjym
Hi,
wj
pinion seal quite do-able in situ. Of course removal might enable more extensive maintenance work.
Old Aug 8, 2024 | 03:00 AM
bladerunner919's Avatar
Can you lower the car so the subframe is resting on blocks, then undo the bolts and raise the body up and off?
Old Aug 8, 2024 | 04:05 AM
RichardS's Avatar
Baxtor is right ..... unless you want to do any other work, all you need to do is drop or remove the prop shaft and you can access the oil seal directly. I changed one last week in a couple of hours.
Of course, changing or topping up the diff oil is a nightmare job on some versions of the X100, actually harder than changing the pinion oil seal. There are ways around this but dropping the diff does make changing the oil a thousand times easier.
Richard
Old Aug 8, 2024 | 07:00 AM
wymjym's Avatar
Yes. there are other repairs/replacements planned.
Harbor Freight has a 450 lb cap transmisson jack, would....maybe this would work. Scissors not hydraulic.
wj
Old Aug 8, 2024 | 07:14 AM
PKWise's Avatar
Wj
If you do decide to drop the entire axle then it is best with a single Jack in the centre (see 1st pic). Just take care. I estimate it weighs over 200 Kg.
Also, don't forget to first detach both the 'hidden' exhaust brackets on top of the Axle (see 2nd pic).
Old Aug 8, 2024 | 07:36 AM
wymjym's Avatar
I think I spent more time removing the exhaust brackets bolts than all the others!
wj
Old Aug 8, 2024 | 02:14 PM
wymjym's Avatar
Alright, opinions please.
Both of these can be purchased for a reasonable price.
This adapter unit uses a ½” thick bolt to attach to a floor jack. I have several 2 ton jacks that could accommodate this type if mounting.
The Harbor Freight screw jack might also work, the upper platform is rather small and I think balancing the suspension might be more of an issue with it.
I appreciate everyone’s thoughts on this.
wj
Old Aug 14, 2024 | 04:33 AM
PKWise's Avatar
Your hydraulic Trolley Jack will suffice. The Adaptor is a great addition for safety.
The scissor screw Jack may not be sturdy enough at height.
Old Aug 14, 2024 | 08:45 AM
wymjym's Avatar
Thanks, will get back to it. 100 degree days keeps me out of garage.
wj
Old Aug 14, 2024 | 06:27 PM
steve massey's Avatar
Very hot in Wimberley, that's for sure.
I'm here too, perhaps we can meet up?
best, Steve
Old Aug 14, 2024 | 08:02 PM
wymjym's Avatar
I'll be in touch.
wj
bullittandy
Nov 2, 2024 03:44 PM
Gino
Aug 21, 2021 01:18 PM
xk8forlife
Nov 25, 2014 08:57 PM
scoobie
Oct 16, 2014 01:32 AM
