Rear wheel free play
Old Aug 6, 2022 | 07:29 AM
Bikergonebald's Avatar
Default Rear wheel free play
Hi guys,
I’ve got my car up on stands and checking the rear wheels for play both have a slight movement when I push and pull the top and bottom. It’s about 1 to 2mm.
there is no side to side movement and the fronts are fine.
is this normal?
Kevin
Old Aug 6, 2022 | 07:40 AM
PKWise's Avatar
Hi Kevin,
I'm afraid that's not OK. It's a sure sign of wheel bearing wear.
I've heard a lot worse though and the UK MOT spec is a bit ambiguous in what amount of play is acceptable..... how much is excessive ?!
Old Aug 6, 2022 | 07:48 AM
Thanks for your reply.
when the alloys come back from refurb I will get it to a garage.
Old Aug 6, 2022 | 08:15 AM
PKWise's Avatar
Kevin,
Read this thread from the X300 forum:
https://www.jaguarforums.com/forum/x...ptable-241036/
Something else just crossed my mind. Your play condition could also be due to wear in the Universal Joint/s because these have a dual role and act as the upper suspension arm - same principle as the e-type shown in this diagram.
Old Aug 6, 2022 | 12:56 PM
astromorg's Avatar
You have to take the differential output shaft end float into consideration
Push the wheel / shaft assembly INWARDS. Zero a Dial Indicator on the diff output flange.
Pull the wheel / shaft assembly OUTWARDS. Note the reading.
Check against the specification;
0 to 0,15 mm GOOD.
0,15 mm + NOT GOOD; Renew the output shaft bearing
Old Aug 7, 2022 | 01:34 AM
tsuppari's Avatar
Originally Posted by Bikergonebald
Hi guys,
is this normal?
Kevin
I do have slight 12-6 movement also, fortunately local MOT does not consider them as issue because there is no 9-3 movement at all (apparently Corvette does have similar issues and rear structure).
Although what parts exactly to inspect/change to remove play would be nice to know as I am planning to drop rear package on next winter.
Old Aug 7, 2022 | 04:27 AM
baxtor's Avatar
I would go so far as to say it is quite normal to have 1 or 2 mm play when measured at the top of the wheel. It will not be apparent with car back on the ground and inward load back on diff output shaft bearings.
l replaced those bearings some years ago because of this free play and brand new bearings made virtually no difference.
Old Aug 7, 2022 | 10:05 AM
bcprice36's Avatar
That's a Big Ole Bearing....It will have to move a little! When it starts to make Noise is when you need to replace.....
BC
Dmcr
Dec 15, 2021 03:29 AM
cyber3d
Jan 18, 2016 04:02 PM
tonyforman
Jul 27, 2015 08:28 PM
Robin Parry
Jan 26, 2012 05:08 AM
Bward
XJ40 ( XJ81 )
Jul 5, 2009 07:23 AM
