Regular -vs- Synthetic Oil in XKR
Old Jun 12, 2008 | 09:22 PM
lockgirl's Avatar
Default Regular -vs- Synthetic Oil in XKR
What's the thoughts of the Jag Techs out there? I'm getting ready for the first oil changeon my2003 XKR.
I am in Florida, the vehicle sits outside, and I only drive it 1-2 times a week. It's a convertible.
It's been 5 months since I bought it and I've only put on 2300 miles.
Do you recommend I go synthetic or regular oil? Any other suggestions on what I may want to get taken care of at the same time? It's pushing 33000 miles.
Anyreason I can't just take itto Valvoline -vs- the dealership? I've used them for well over 10 years with my Fords and have never had any problems.
Thanks in advance!
Old Jun 13, 2008 | 09:29 AM
ken@britishparts.com's Avatar
Default RE: Regular -vs- Synthetic Oil in XKR
My two cents:
Just keep the oil changed. That's the biggest concern.
Yes, anyone can do an oil change on these cars. Just make sure they refill with the proper amount.
Of course, if oil prices keep going up, soon the synthetic will be less expensive than oil. I wonder if everyone will want regular oil once it's the most expensive? Hmm.......
Old Jun 13, 2008 | 10:51 PM
GordoCatCar's Avatar
Ken: Thats an Interesting observation regarding the cost inversion of synthetic and dino lubricants. I hadn't thought of that before....
Old Jun 14, 2008 | 10:27 PM
ibjags's Avatar
for the miles you put on the car id go with dino oil
Old Jan 13, 2010 | 08:47 AM
StrateLoss's Avatar
I would go with a group4 synthetic. Before you make your decision read up on the different oils and the benefits of both. A great place to start is right here
http://www.bobistheoilguy.com/forums/ubbthreads.php
Old Jan 13, 2010 | 09:21 AM
H20boy's Avatar
Well, after 18 months, I'm sure lockgirl has changed her oil by now. Lovin the resurrection guys.
Old Jan 13, 2010 | 10:14 AM
SeismicGuy's Avatar
My 95 Corvette (now sadly gone) was the first car I owned where Mobil 1 Synthetic was the required oil. In the 14 years I owned the car I had the oil changed religiously every 6 months (about 3,000 miles for me) and I noticed the oil looked as clean at the 6 month mark as when it was freshly installed. Moreover, when checking the oil level it was always at the proper level (never burned or lost any oil). So I am a fan of the synthetics (at least Mobil 1) and was also wondering what type of oil is recommended/required for the XKR.
Doug
Old Jan 13, 2010 | 11:27 AM
Mikey's Avatar
Synthetic oils were required in some C4 Corvettes for reasons completely unrelated to lubrication. GM had to decide between fitting an oil cooler to deal with temps in one particular area of the engine that ran hot enough to coke 'regular' oil, or not fit an oil cooler and pass ongoing operating costs onto the consumer by specifying synthetic oil. They chose the latter.
Unless the OEM specifies synthetics or the longer change intervals are going to be taken advantage of there's no real reason to use synthetics.
Old Jan 13, 2010 | 08:28 PM
StrateLoss's Avatar
I didnt even realize this thread was bumped from the dead lol
Lockgirl, I hope you changed out that oil !
Old Jan 13, 2010 | 09:00 PM
test point's Avatar
Wonderfully appropriate attachment.
Wish I knew how to do that!
tp
Old Jan 13, 2010 | 09:08 PM
StrateLoss's Avatar
here a link to the site, dont mind me getting stuck on the dirty ones lol
http://www.forumammo.com/cpg/display...bum=11&pos=688
Old Jan 13, 2010 | 11:16 PM
H20boy's Avatar
wasnt your fault strate, new guy (freshly banned for false registration) duped ya! His post was a copy n paste from another post.
Old Jan 14, 2010 | 03:05 AM
viscoussquirrel's Avatar
tp
It's EASY!
While dropping your head slowly, bring your hand briskly up to your face. Timing on this is crucial... Fast hands and a slow head = a self slap. Slow hands and a fast head drop = a head but. you need to match the speed perfectly to get the facepalm!
LOL
Old Jan 14, 2010 | 10:23 AM
H20boy's Avatar
good one viscous
Old Jan 14, 2010 | 01:43 PM
daddyo007's Avatar
Hawaii-ians, Got to love the freedom to think like that.
Try that around here and your well, different.
Long live the freedom to THINK for yourself!
Old Jan 16, 2010 | 09:24 AM
Marc's Avatar
When I first heard of synthetics, it was only the racers and avaiation people that used them previously. That gave them a lot of validation. I switched to Mobil One and installed an accessory oil filter which filtered down to one micron. (1/40,000"). I never changed the oil again. Went 90,000 miles without an oil change only changing the aftermarket element every 6 months and adding a quart. One day I accidentally overheated the engine and ruined the valve seals. I removed the engine, and tore it down for inspection and a fresh up. It was clean as a whistle inside. Threw in a cheap overhaul kit and went some more. I eventually sold that truck, but the engine out lasted the truck. This is why BIG OIL and the auto people do not endorse modifying your engine.
Old Jan 16, 2010 | 10:05 AM
Mikey's Avatar
Marc,
The average engine outlasts the car that it's in anyways- in spite of poor maintenance by the owner. If an engine does die prematurely, it's rarely oil system related.
SD96XJ6L
Jan 12, 2022 04:30 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
kstevusa
Sep 7, 2015 01:12 PM
