Repeated Failure of the Fuel Pulse Damper
Old Oct 28, 2012 | 11:03 AM
chopr's Avatar
Default Repeated Failure of the Fuel Pulse Damper
I ran into a gent last evening that was quizzing me as to why his fuel rail pulse damper continues to fail. It seems his mechanic has replaced this item four times, and yet the new parts invariably will fail once again. I suspect that the fuel pump control module is allowing the pump to operate at maximum pressure at all times, possibly asking too much of the damper to control. Looks like I may be helping this man get to the root cause of the problem. Any ideas out there? I found a few threads concerning these dampers, but nothing like this.
Last edited by chopr; Oct 28, 2012 at 11:05 AM. Reason: no vehicle specified, 2003 XK8 (may be XKR, not sure)
Old Oct 28, 2012 | 07:57 PM
Kevin,
17 views so far and no takers. Time for me to ask a dumb question to get the ball rolling.
For 'fuel rail pulse damper' is he talking about the Fuel Pressure Regulator
or the FRP (Fuel Rail Pressure) sensor?
Repeated Failure of the Fuel Pulse Damper-2003-fuel-rail-pressure-sensor-na.jpg
These drawings are both the NA engine.
Old Oct 28, 2012 | 08:38 PM
maxwdg's Avatar
I'm sorry, I didn't see this thread until Sunday evening Oct 25.
Recently, I had quite on ordeal with one of the fuel pulsation dampers on my 2003 XKR. However the "fix" was pretty straight forward - even if it did involve a tremendous amount of work... And set off an apparently mostly un-related electrical problem that defied dozens of ideas and attempts to fix... And then the electrical gremlin up and "cured" itself!!!!!! Ghosts of Conventry
What I'd like to know is what his problem is - exactly. Mine was a slow leak that eventually turned into a bad leak at one of the two dampers (which on my car, looks nothing like the diagram that GGG put forth) Perhaps the Supercharged cars are substantially different. I have attached a picture of the dampers on my '03 XKR.
Anyhow, we need more info - year and model of car and a better description of what the symptoms are.
Attached Thumbnails Repeated Failure of the Fuel Pulse Damper-pulsedampers2003-sc-4.2l.jpg
Old Oct 29, 2012 | 02:37 PM
Originally Posted by maxwdg
.................. Mine was a slow leak that eventually turned into a bad leak at one of the two dampers (which on my car, looks nothing like the diagram that GGG put forth) Perhaps the Supercharged cars are substantially different. I have attached a picture of the dampers on my '03 XKR...................
Yes - the equivalent S/C drawing matches your pic. I didn't include them because we don't yet know MY etc.
Old Dec 30, 2014 | 11:43 AM
neal.hutchinson's Avatar
maxwdg,
I have got a leaking fuel pulsation damper on my 2005 XK8 and am desperate to fix it. Having checked online and with the dealer, the damper is not available on it's own, only as part of the Fuel Rail assembly (AJ811304) at exorbitant cost(!). Elsewhere on the forum I found a post saying that AJ84080 is the part, but having ordered one, while it is clearly a jaguar fuel pulsation damper, it is not the right size for an XK8!
Please help with any info from your fix.
Old Dec 30, 2014 | 12:29 PM
brgjag's Avatar
Send it out to injectorrx.com Mine on my 03 the dampeners were leaking. Best fixis to have them CAPPED. I did mine and they cleaned up the injectors also.
Old Dec 30, 2014 | 12:48 PM
brgjag's Avatar
Most all threads here on this say have the dampeners capped, putting in a new o-ring most have found that they start leaking again pretty quickly. I just had mine done and others have by InjectorRx.com. He is good. He got mine on a friday, fixed, and back out the same day for 250 bucks. Be careful NOT to bend the crossover fuel line at the front of the rails, that hard rubber had plastic in it, I did not take care of mine thinking it was just a rubber line and cracked the inside plastic, it was only like 10 bucks more for a fuel line replacement and clamps from them. If you can leave the injectors in the rail. They WILL replace all the orings on the injectors, do not reuse old ones. I reused the old one on my regulator (I did not send it with the rail, took it off) and it started leaking right away after I put it on.
They will pressure check everything also. My injector bodies, a few had cracks, he just clued them up.
This is your best solution to the problem, as you found out Jag has no parts, wants the bank for a new rail that is not even avail.
Be gentle when you pull the connectors off the injectors, a few of mine I snapped the push clips that hold them on the injectors securely. I just pushed them back on the injectors when i put it all back together, thus far no issues.
Old Dec 30, 2014 | 12:55 PM
brgjag, many thanks - that is clear and I will do exactly that. I am really impressed by the quick response and clarity of your summary; I admit I was going around in circles reading the various threads associated with this problem!
Thanks again,
Old Dec 30, 2014 | 01:03 PM
brgjag's Avatar
I find the same issue here at times, searching for an issue and getting multi threads with diff ways to do things, ways at times I have no clue what it means so I just start another new thread and ask very deliberate questions so I GET IT, ha ha ha
At times you won't get a fast response but over all the help here is quick.
I assume you can take the fuel rail off, understand how too?
Old Dec 30, 2014 | 01:04 PM
brgjag's Avatar
my clarity comes from having done this very repair recently, ha ha ha
Old Dec 31, 2014 | 04:41 PM
maxwdg's Avatar
Hello Neal, brgjag came to your rescue first and I totally agree with his suggestions (no surprise to anyone having read my exhaustive posts on this subject from back in 2012.)
The fellow at InjectorRX in Houston, is possibly the most qualified to cap those worthless leakers of any shop you could get this done at. During our long conversations back when I was having the same issues with my '03 XKR, we both came to the conclusion that elimination of the dampers would not affect the operation of the fuel rails on our V-8 engines. He had not attempted to cap the damper cups at the time we were working through this - so I asked my father-in law to machine some caps out of stainless steel and I silver soldered the cups closed myself. But InjectorRX has obviously perfected the modification and performs such at a VERY reasonable price these days.
This IS positively your solution. Best of luck to you and Please Please Please don't use fuel containing alcohol if is at all available to you! Our entire fuel system, from the pump to the injectors is allergic to that swill.
Old Dec 31, 2014 | 05:00 PM
brgjag's Avatar
I noticed a very do slightly louder injectors after my dampeners where capped and I may just be imagining things, and I have not put the engine cover back on the motor yet due to other repairs. No diff in how the car runs either.
Old Jan 2, 2015 | 07:39 PM
chopr's Avatar
Great solution. Good to know there is a "fix" out there for the issue!
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
RoyLittle0
May 25, 2023 02:38 AM
hoodun
Oct 2, 2015 10:13 PM
