replacement engine green label pic?
Old Sep 21, 2010 | 08:27 AM
mr smith's Avatar
Default replacement engine green label pic?
Hi, i have a 97 nikasil engined XK8 i have been rebuilding. i dont have any service history as i bought it salvage, but i understand that quite a few engines were replaced under warranty and are identified by a green label. Does anyone have a photo of its location or can tell me where it is exactly located?
cheers.
Old Sep 21, 2010 | 08:55 AM
daddyo007's Avatar
Its on the passenger side head in the rear close to the firewall. You might have to remove the breather pipe to see it.
Old Sep 21, 2010 | 12:50 PM
mr smith's Avatar
Default hi
thanks dad, but is that on a right or left driver?
Old Sep 21, 2010 | 12:58 PM
roverman's Avatar
Offside to you, Mr Smith
Old Sep 21, 2010 | 04:08 PM
Brutal's Avatar
Theyre acually overheat labels that change color if the engine is overheated. Theyre about an inch square. Also should have a black oil pan if replaced.
Old Sep 21, 2010 | 10:04 PM
Two jags's Avatar
Here is a picture of one that was in a book I had. This is what's on the tag "genuine jaguar exchange product part no., xxx xxxx xx, exchange serial no. xxx xxx" .The name of the book is You and your Jaguar XK (Nigel Thorley) This is a great book.
Old Sep 21, 2010 | 10:09 PM
Brutal's Avatar
Ahhh THAT tag, forgot about that one
Old Sep 22, 2010 | 01:28 PM
mr smith's Avatar
Default hi
thanks lads thats just what i was looking for. Fingers crossed eh?
Old Sep 6, 2012 | 05:52 PM
Fedoraja1's Avatar
Does this amazing green label speak to the quality of the tensioners as well?
Old Sep 7, 2012 | 07:09 AM
daddyo007's Avatar
NO, I replaced my tensioners with about 40K on the reman engine. Thought there was no indication I need to I wanted to. I found the base of the primary ones were beginning to crack. The slippers on the chains were cracked in several places.
casepie
Aug 30, 2015 09:49 PM
aquifer
Aug 29, 2015 04:54 PM
Will P
Aug 27, 2015 06:52 PM
dpappyp
Aug 27, 2015 06:31 AM
Jaguar Forums Editor
Jaguar Press release
Aug 26, 2015 05:08 PM
