Request for Jag shop in Raleigh, NC area
Old Feb 29, 2012 | 09:28 AM
eagledancer's Avatar
Default Request for Jag shop in Raleigh, NC area
Hi All,
The wife and I are on our 'round the USA road trip and are visitng friends in Sanford, NC. Yesterday the Jag (2000 XK8 conv't) started acting up, giving me a restricted performance message for short periods, then the last one gave me a check engine light, too. I'm going to go get the codes read and see what it throws and go from there. Just in case I have to have it worked on, I would like a recommendation for a shop I can take it to, hopefully close by.
Thanks to all you tarheels and those who are not.
Old Feb 29, 2012 | 09:51 AM
Jon89's Avatar
The closest dealership is Leith Jaguar in Cary, NC. Phone (800) 868-0320. They were insanely expensive for a number of years for both parts and labor, but they have since learned that they do not live in a vacuum and Jaguar owners have choices....
A well-respected independent shop is Flying Circus English Cars in Durham, NC. Phone (919) 596-4250. Should still be more reasonably-priced than Leith....
I would assume that Sanford, NC has an Advanced Auto Parts, an Autozone, or a Pep Boys. You should be able to get your standard OBDII codes read for free at any of those....
Good luck and safe travels....
Old Feb 29, 2012 | 09:59 AM
The Coupe's Avatar
"Reverend Sam" is near Raleigh...perhaps he'll have an idea. Perhaps you should send him a private message to make sure he sees your question.
Good luck.
Old Feb 29, 2012 | 12:52 PM
Reverend Sam's Avatar
Jon said what I would have said.
Old Feb 29, 2012 | 06:58 PM
Update on issue. The codes all revolved around misfires of plugs. I suspect it has to do with my replacing the valve cover gaskets before the start of the trip. The misfires stared after we were parked on a off camber downhill slope to the left and I suspect that oil has gotten into the plug tubes as the misfire codes are for the plugs that would be most affected. Tomorrow I will pull the plug cover and coils and have a look see. I torqued the valve cover bolts to spec, but didn't have time to recheck after a few heating/cooling cycles. So hopefully all will put right soon.
Again thanks for your input.
Old Mar 1, 2012 | 11:08 AM
Well, I found very little oil in plug tubes, appears to be left over from before I changed out valve cover gaskets, so I must have done that right. I drove the car about 120 miles yesterday and no recurrance of restricted performace light, although I still have the check engine light, not sure if that will self reset. Hopefully it was just one of those things that Jags are prone to do once in a while and our trip will continue.
Old Mar 1, 2012 | 11:46 AM
Jon89's Avatar
Possibly moisture in the throttle body....
Forcedair1
Sep 8, 2025 01:57 PM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
allenman85
May 10, 2021 03:11 PM
philwarner
Sep 5, 2015 10:05 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
