right front wheel noise
Old Jun 23, 2017 | 11:49 AM
oldtimer69's Avatar
Default right front wheel noise
Sounds like rotor rubbing but it is not showing any marks on backing plate. Took off rotor and turned hub no noise bearing seems tight put rotor back on and no noise I don't want to put it a back and have the same noise anyone ever have this happen, am I missing something.
Old Jun 23, 2017 | 04:05 PM
GordoCatCar's Avatar
The first thing that came to mind was the dust sheid, which is easily deformed, became bent and is rubbing agains the rotor. But, you said you checked for the rotor for scraping against the dust shield backing plate as in the pic below, correct? I assume when you did that and check again, you had the rotor bolted tight against the hub assy? Better even if you remounted the wheel, maybe?
Possible that the rotor is out of plane and scraping something on the caliper? I've checked for runout when nothing else seems to be logically causing something like what you describe.
Attached Thumbnails right front wheel noise-front.susp-2-.jpg   right front wheel noise-rotor.runout.check-001.jpg
Old Jun 23, 2017 | 04:33 PM
Johnken's Avatar
Oldtimer, maybe you could say more about what you hear? When you hear it and how loud it is.
I don't want to assume I know exactly what you mean about rotor rubbing.
John
Old Jun 23, 2017 | 05:27 PM
oldtimer69's Avatar
I would hear it all the time when the wheel was turning, was like the rotor rubbing caliper or rubbing sound. I had to use a puller to get off the rotor and now sound is gone. so I put it back together and now raining so will check tomorrow. Thank You all
Old Jun 23, 2017 | 05:39 PM
frankc's Avatar
Totally different subject, what paint did you use under there? Love the finish.
Old Jun 23, 2017 | 06:59 PM
The black is standard off the shelf black enamel. Probably from Home Depot or Ace Hardware.
The silver is G2 caliper epoxy / paint.
Amazon Amazon
Old Jun 23, 2017 | 07:04 PM
Whenever I install a rotor onto a hub, especially when it is a tight fit, I always insure the mating surfaces are clean and usually run a file across each to eliminate burrs or anything that could affect fitment. Also, I use a light coating of anti-seize to keep the metal parts from any dielectric issues forming.
Old Jun 26, 2017 | 06:38 PM
oldtimer69's Avatar
Thank you all I put it back on and no more noise Thanks again
