Rubber mount for air filter box
Old Jun 6, 2014 | 05:29 AM
Jacob67's Avatar
Default Rubber mount for air filter box
Hi, while replacing the sway bar bushings yesterday we discovered that the rubber mount that stabilizes the air filter box was thorn apart.
I checked online and found a price of £ 42,- for part number EAC8130.
Luckily I know my inventory and had the exact same part for less than £ 3,-.
Old Jun 6, 2014 | 05:40 AM
jamdmyers's Avatar
Great price, I'd damaged mine when I pulled the air box to replace the SC water pump.. I've been wanting to replace it but at $45 for a rubber mount I can't get myself to pull the trigger.. guess I just need to keep looking..
Old Jun 6, 2014 | 06:05 AM
steeevo's Avatar
I need one of those too, where did you get it for £3
Old Jun 6, 2014 | 06:08 AM
Jacob67's Avatar
I'll send you a PM
Old Jun 6, 2014 | 06:28 AM
DevonDavid's Avatar
Steevo,
If you're in the UK, look here :
Rotax Max Kart Exhaust Rubber Bobbin Mount x 4 Pack M8 Thread Anti Vibration | eBay
or just do a search on "Bobbin Mount". I don't know if the sizes are identical, but can't be that far off !
Old Jun 6, 2014 | 06:38 AM
steeevo's Avatar
found one on ebay thanks WALKER 81229 Exhaust System Holder for RENAULT RODEO (1970-1987) | eBay
Old Jun 30, 2014 | 06:24 PM
Jandreu's Avatar
Bought the mount below
New Jaguar Vanden Plas XJ6 III L Sovereign Drier Mount | eBay
Works perfect, same size and threads. Just unscrew the old broken parts and screw this one on. The part attached to the fender has a captive nut under the fender so no need to remove the fender liner.
Old Jul 1, 2014 | 03:15 AM
Originally Posted by Jacob67
......... I checked online and found a price of £42 for part number EAC8130...........
I couldn't believe that for a tiny metalastik so I checked a few Jaguar parts suppliers. Sure enough, £42 ($72) is the UK cost for OE including tax.
Old Jul 1, 2014 | 11:17 AM
RaceDiagnostics's Avatar
Looks like the same part needed to mount the heater pump bracket as well as the engine oil cooler rediator, both have silly prices from Jag.
Old Jul 2, 2014 | 04:41 AM
ArtyH's Avatar
Talking
Earlier this year I had the same problem, but could not find the part.
I used gorilla glue and it worked great.
The ones on ebay in the U.S are around $30 shipping to the UK, surely this cannot be correct. I have not sent anything overseas for a few years but those transport charges are way over the top.
Old Jul 2, 2014 | 12:34 PM
BobF's Avatar
I replaced one several years ago on a 99XK8, failure was caused by a failing motor mount allowing the engine to rotate.
Old Apr 12, 2025 | 04:42 PM
Brian G's Avatar
Just replaced mine with these units off of Amazon Canada. ~ $13 CAD for 4. They fit perfectly although the base is not hex.
Should work for the oil cooler isolators, too.
smoggyx100
Mar 24, 2023 03:39 PM
NYCJAG2006
Oct 1, 2022 12:07 PM
carsnplanes
Jul 29, 2022 02:19 PM
emgun
Mar 23, 2015 09:50 PM
hallam
Feb 17, 2010 07:18 PM
