Sea foam?
Old Mar 17, 2016 | 12:21 PM
jetjack's Avatar
Default Sea foam?
Hi all,
Just finished changing all my hoses, including the "Octupus" hose.
The intake plenum and cylinder intake ports and valves are all coated with a wet, sticky, black soot. I'm trying to find an additive to break this down over time.
Was looking at "Seafoam" Anyone have experience with this product, or other possible solutions?
Thanks,
Jack
Old Mar 17, 2016 | 02:38 PM
brgjag's Avatar
Are the parts back on the car or off still? If they are off try looking into Dry ice blasting, google your area for a restoration outfit that may do it, also look into a soda blasting company. I used Dry Ice Blasting to clean mine all up, but my stuff was off the car.
Old Mar 17, 2016 | 03:43 PM
Gus's Avatar
Gus
BG44k is the best product to use.
Old Mar 18, 2016 | 06:40 AM
marvin.d.miller's Avatar
I'll probably draw fire for this, but the hint should be taken from the name...Sea Foam. If you perform a proper search to determine it's true use, you will discover that the product was developed for outboard motors and other water craft. It's intended use was never for automobile engines until some backyard mechanic gave it a shot.
My advice is to always stick to products that are developed for what you are trying to do. So, follow Gus's advice....and use car products one cars, boat products with boats.
Old Mar 18, 2016 | 08:55 AM
Mikey's Avatar
Spot on. Works great on WWII vintage 2 stroke outboard motor carbs. Does nothing on modern cars except create clouds of smoke as the product (50% oil) burns off.
Old Mar 18, 2016 | 08:38 PM
Bhpbug's Avatar
I will say with 39 years of experience in the power sports industry, I.E motorcycles, snowmobiles, watercraft, atv's, Utv's, and automobiles, while the product sea foam has been used and discussed, I have never seen it do anything to support it's claims. I will also agree with Gus 100%, that BG 44K IS the proper product to use and it works very well indeed. BG 44K should be used by anyone with any of the above vehicles that I mentioned earlier.
Old Mar 18, 2016 | 08:53 PM
Mikey's Avatar
It can't and won't if poured into the intake, crankcase or gas tank as commonly practiced.
Seafoam is nothing more than naptha, rubbing alcohol and light petroleum oil. None of those compounds individually or in combination are effective at doing much in modern engines of any type, especially when diluted in gas or oil.
When it was invented in the 1930s, it's sole purpose was unclogging carbs on poorly maintained two stroke outboards. Castor oil was the standard pre-mix oil used at the time.
Much like WD40, the company marketeers have spun the product a 1000 different ways to keep sales going. Whether it works or doesn't is not their concern.
Old Mar 19, 2016 | 05:07 PM
jetjack's Avatar
Thanks for the input, I found a Honda Dealer nearby that carries BG44K, I'll give it a try
Cliff5.0SC
Jun 13, 2024 09:00 AM
JessN16
Apr 27, 2016 12:12 AM
sikest
Mar 22, 2016 02:25 PM
bigdhenderson
Mar 16, 2016 11:48 AM
kr98664
Mar 15, 2016 12:33 PM
