Seat Back tilt motor...help
Old Feb 21, 2016 | 10:37 PM
deelli's Avatar
Default Seat Back tilt motor...help
Want to check the motor on my 2002 XK8 seat back tilt motor (drivers side)...need to know which pins in connector to power to test motor.
Thax
Old Feb 22, 2016 | 10:52 AM
The Coupe's Avatar
You may have a problem with your motor, BUT...there's a known issue with the circuit board in the seat control modules. Summary: over time, the edge of the module casing rubs through a tiny electrical circuit on the circuit board, and until that little circuit is repaired, the seat loses its ability to tilt.
Your driver and passenger seat modules are interchangeable...one way to check for this problem is to switch them and see what happens (assuming at least one is working).
Here's one thread talking about that problem...there are others.
https://www.jaguarforums.com/forum/x...-moving-99102/
Old Feb 22, 2016 | 01:11 PM
stingray71's Avatar
Yes, I just had this same issue where the other seat functions would work but not the incline/recline. It was the seat control module problem described above.
sg18438
May 9, 2023 07:06 PM
ET1
Sep 8, 2016 09:11 AM
02jagstype
Feb 19, 2016 04:06 PM
JagHeadaches
Feb 18, 2016 07:46 PM
dr.fixit
Feb 16, 2016 06:33 AM
