Seat memory
Old May 28, 2015 | 05:32 PM
Chuck Schexnayder's Avatar
Default Seat memory
Hi all-----
On my XJ8L, When I get in, shut the door, as soon as I stick the key in the ignition, the steering wheel, mirror's, and memory seat all go to the drivers memory setting. When I pull the key out, all return to the exit setting.
On the XK8, as soon as I stick the key in the ignition, the mirror's move and the steering wheel moves to the set position but, the seat just sits there. (no pun intended) If I push the #1 set button, the seat will then move to the pre-set position. When I remove the key the steering wheel and mirrors return to the exit position, but not the seat. I have to push button #2 (which I preset to the exit position) to get the seat to move back so I can get out of the car.
Thinking (wrongly) that the module was bad, I sent the seat module to the guy in CA----Darrell Turner, who most folks use (Plus he's retired NAVY-----helping my fellow VET)----and he said he could find nothing wrong with it except a little corrosion here and there. Back in the car, same situation, everything except the seat works when the key is inserted or removed.
Seems like I read a good while back that there is some kind of ring on the ignition that senses the chip on the key when it's inserted to cause all this to happen. If this is true, can this be what's wrong and can it be replaced if bad? Can a good local locksmith shop replace it?
Any help appreciated---------Cheers
Old May 28, 2015 | 09:07 PM
motorcarman's Avatar
Blessed Bovine (holy cow) I'm tired of posting this!!!!!!!!!!!!!!!!!
This is all in the large file download area.
bob gauff
File Type: pdf
File Type: pdf
Old May 29, 2015 | 03:11 AM
dibbit's Avatar
Chuck - my XKR does exactly the same as yours - I didn't even know there was an easy entry/exit setting. Are you sure there should be?
Old May 29, 2015 | 06:47 AM
test point's Avatar
He just set his Driver 2 button to an entry/exit position. No auto exit option on the XK8/R.
Old May 29, 2015 | 10:16 AM
dibbit----------
No, I'm not sure dibbit. To get around the fact that there might not be, I've done as 'test point' said and set the #2 memory button to an exit position. It does seem odd that Jaguar would do that however.
If that's the case, having an automatic memory system for anything seems a waste, but getting out of the thing in my case is an almost necessity. ;-))
Old May 29, 2015 | 10:50 AM
fmertz's Avatar
Default Too risky
Chuck,
My read is that with this little leg room in the back seat, an automated translation of the seat is a disaster waiting to happen. I could see Jaguar having this feature in a sedan, but for the coupe/convertible, it is a non-starter. Like I said, just my read.
Old May 29, 2015 | 11:52 AM
dibbit's Avatar
Originally Posted by fmertz
Chuck,
Yes, that makes perfect sense and explains the lack of that feature on our cars.
Old May 29, 2015 | 01:49 PM
To All:
Seat problem solved. There is NO "entry/exit" seat feature on the XK8.
Solution: Set the door buttons to move the seat........
Other features "Steering Wheel and Mirrors" can be program and will work on entry and exit.
Old May 30, 2015 | 04:49 AM
jamdmyers's Avatar
Originally Posted by Chuck Schexnayder
To All:
NOTE: Not sure how many people do this (the extra tall folks probably) but it's known that constant movement of the seat may eventually post a SRS error, this is due to the harness (specifically the connector) under the seat being flexed. Both times I had the SRS was due to me moving the seat down and back (but maybe not that motion) just a FYI, maybe a new thread with a poll?
Old May 31, 2015 | 08:44 PM
Jag#4's Avatar
I am a little vertically challenged, so the seat exit thing is not an issue for me. However, I set #2 memory for the generic taller type mechanics.
If I take it in for new tires (back ones done this weekend) or inspections. etc. I use #2 on exit, so the mechanic doesn't hit every frickin' button on the seat until they get a setting that allows them some legroom.
bdboyle
Sep 16, 2019 05:58 PM
NS2000XKR
Jan 1, 2017 10:41 AM
sg997tt
Oct 9, 2015 10:57 PM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
