She is off the lift, need advise please!
Old Feb 28, 2011 | 10:08 AM
Mish_Mish's Avatar
Default She is off the lift, need advise please!
Finally, I pulled my XKR off her gynecological chair and drove this entire weekend. After having her on a lift for nearly 2 weeks, working on at least 10 different issues, it was nice to finally feel that supposedly $80K goodness
I have to say, OMG, is she one smooth tigress, or what!?!
1. Only one "restricted performance" this morning, which went away after restarting and so far did not come back. So how do I find out what the complaint was? I drove very gently, alowing car to warm up and than I noticed the orange light and all!???
2. My rear speakers seem to only make low frequency boom, much like subwoofer and when I try to fade sound to the rear, I can only hear the low booming. Front seem to sound very nice though. Am I missing something here?
3. Low cooland warning came on one time, so I topped about half qt. of orange coolant and it seems to be gone since then. Where is that coolant level sensor and why only half qt. makes so much difference?
4. Also, I see some pictures with clock dial on navigation screen, however mine only does Jaguar logo and little digital clock in the corner, how do I switch to the manual dial option?
Thank you in advance, your help is always appreciated!!!
Old Feb 28, 2011 | 10:25 AM
WhiteXKR's Avatar
3. Low coolant warning came on one time, so I topped about half qt. of orange coolant and it seems to be gone since then. Where is that coolant level sensor and why only half qt. makes so much difference?
1. Check if she logged any fault codes with a code reader.
2. If you cycle throught the 'MODE' button on the headunit, eventually you will reach the 'SW' (subwoofer) volume setting, perhaps it is too high, or the BASS setting is too high.
3. Level sensor is in the fill tank, perhaps there was some air that just needed to bleed out. See if it happens again.
4. It is not a selectable option. The later version nav. DVD has the analog clock instead of the leaper. The latest version is only a year or two newer, so it may not be worth the upgrade, unless you are really in love with the analog clock.
Old Feb 28, 2011 | 11:15 AM
Mish_Mish's Avatar
I checked the MODE on radio and it is all in default setting, bass is normal, SW is at 1. I think I am simply not getting any general sound range on the rear speakers.
checked colant reservoir, it has 3 hoses going out of it, but no wires.
Old Feb 28, 2011 | 11:26 AM
WhiteXKR's Avatar
Not sure about your radio, there might be an issue with your power amp.
Look again, the coolant sensor is there, it is underneath the resevoir, toward the end near the firewall.
Old Feb 28, 2011 | 11:36 AM
H20boy's Avatar
one small addition...
2. The system is operating normally, there are no 'mids' or 'highs' in the rear...bass only for the convertibles.
4. whitexkr is correct, check your disc, the latest version is Jaguar P/N is 4W83-10E898-GA , Alpine P/N is BM9JG91F, copyright 2003 IIRC. This one will get you the clock and a possible update to the maps. Ebay might score you one for $125 or so, or contact me via PM for another option.
Old Feb 28, 2011 | 11:47 AM
Reverend Sam's Avatar
I think on the Nav unit he's wondering how to get out of clock mode and into nav mode. On the bottom left there is a little knob. It's kinda like a joystick. If you push it in it will take you into nav mode, then you can navigate through all of the settings and stuff with the little joystick. Pushing it in is the same as clicking the button on a mouse.
By the way. Are you from Russia or Ukraine or someplace? I've noticed that you drop the articles "the" and "a" sometimes, and because of that every time I read your posts I imagine them being spoken with a Russian accent! LOL!
Old Feb 28, 2011 | 11:52 AM
Brutal's Avatar
Damn waterboy beat me to it, yes you dont have anything but low response in the rear speakers, normal
Old Feb 28, 2011 | 02:28 PM
Mish_Mish's Avatar
I am of Russian origin, it very perceptive of you my friend
I do drop occassional article, or two, but only for the sake of staying foreign and keeping my authentic flavor
P.S. thank all y'all for helpin' me out, you hear?!
Old Feb 28, 2011 | 11:25 PM
H20boy's Avatar
Hey Brutal, I think that was meant for you and I thanks Mish^2
Old Mar 1, 2011 | 12:05 AM
Were you able to get your nav unit working the way you wanted?
Old Mar 1, 2011 | 10:47 AM
Mish_Mish's Avatar
Apparently I need new DVD to upgrade to the manual clock dial look.
At this point, I will not be investing in upgrading crap into less of a crap and possibly will consider installing that modern navigation piggy back system.
SD96XJ6L
Dec 27, 2025 09:58 PM
JaguarLover101
48
Jun 12, 2023 10:28 AM
Inspector
Oct 17, 2015 12:51 PM
hoodun
Oct 6, 2015 08:34 PM
Collector1
Sep 26, 2015 05:28 PM
