sheared bleed nipple
Old Oct 9, 2022 | 01:43 PM
Ant Buck's Avatar
Default sheared bleed nipple
Managed to get three undone, but sheared off the last one. Has anyone experienced this and how did you remove it. Many thanks. Anthony.
Old Oct 10, 2022 | 01:15 AM
Pistnbroke's Avatar
If you are talking about a bleed nipple on a brake calliper then just forget it and bleed it by loosening the brake pipe fitting
Old Oct 10, 2022 | 04:02 AM
STLTHMSTA's Avatar
Left handed drill bits. If you're lucky it will snag it and back it out. The worst you can do unless you mangle it is drill the hole bigger a step at a time until you can free it. Otherwise you're buying a new caliper. TM
Old Oct 10, 2022 | 04:17 AM
Pistnbroke's Avatar
Soak it in brake fluid then try an easy out . Otherwise, there are companies that will drill it out then re-tap to take a larger nipple. If you google "brake repair specialists near me " Then get on the bell.
Bet it did not have the rubber cap on it and water got in or fill with grease.
Old Oct 10, 2022 | 07:58 AM
Brizzy's Avatar
If you can’t remove the old bleed nipple, drill out and fit this. See pic.
Old Oct 12, 2022 | 03:26 AM
dibbit's Avatar
The bad news for you is there are 8 bleed nipples on those brake calipers, not 4.
iramphal
Jul 21, 2022 04:56 PM
orangeblossom
May 3, 2021 07:39 AM
RaceDiagnostics
Apr 4, 2016 04:00 PM
orangeblossom
Aug 4, 2015 03:27 AM
azeteg
Aug 3, 2014 05:58 PM
