Sheared Differential Output Stud
Old Dec 16, 2022 | 11:48 PM
H20boy's Avatar
Default Sheared Differential Output Stud
My first nut that I removed on the halfshaft to differential stud sheared right off! Following that, I used a little PB blaster and heat...no problems on the others. So, based on the image of the new stud I ordered, it appears to be a press-in stud, but how the heck do I get the old one out and the new one in? There isn't enough room behind the head of the stud to maneuver it out, then back in. Tell me I don't have to pull this thing apart. Any instructions and advice?
Old Dec 17, 2022 | 01:50 AM
Pistnbroke's Avatar
looks like circlip 16 to take it out. Sorry. You could coat the broken one with loctite and just use 3
Old Dec 17, 2022 | 03:33 AM
dibbit's Avatar
Is there room to put the bolt in the other way around? I.e. the nut goes on the differential side and the bolt goes on the half-shaft side? Even if you had to cut the bolt down in length, its a better option than no nut.
Old Dec 17, 2022 | 04:04 AM
baxtor's Avatar
Post deleted by author
Old Dec 17, 2022 | 08:41 AM
motorcarman's Avatar
Remove the giant circlip, pull the shaft assy out, repair, reinstall shaft assy and circlip, DONE!
Old Dec 17, 2022 | 11:10 AM
H20boy's Avatar
Ok, well…I’ll give it a shot with the circlip removal and pull the assembly. Thanks for the advice.
Old Dec 17, 2022 | 03:01 PM
baxtor's Avatar
l suggest if you don't own them already, get yourself a pair of turn screw adjusted or ratchet locking circling pliers. They will make the job easier.
jerry_hoback
43
May 20, 2022 02:05 PM
yachtmanbuttson
Jun 29, 2021 09:34 AM
skinnypuppy_22
Jan 4, 2017 12:06 PM
XJeej
Dec 15, 2015 12:14 PM
harryc
Sep 7, 2013 10:32 PM
