Shock mounts
Old Aug 24, 2023 | 07:37 PM
kemp neal's Avatar
Default Shock mounts
What are the best replacement front shock mounts for the x-100?
Old Aug 25, 2023 | 07:01 AM
Jon89's Avatar
The ones that are custom-made by forum member Wayne (cjd777) right here in North Carolina. Many of us have been running them during the past couple of years. PM him for details....
Old Aug 25, 2023 | 04:10 PM
Chris Lutz's Avatar
My driver's side suspension started clunking badly today, about 3 miles into a drive. Here's what I found. Thanks for the post, I may have to contact Wayne. Assuming I can get original replacements or Wayne's pieces, is this a repair I could do myself, or should I use my trusted Jaguar shop? Thanks!
Old Aug 25, 2023 | 06:56 PM
baxtor's Avatar
Seeing those pics, two things immediately come to mind.
(1) if Wayne can't help PM me, l can help.
(2) Find a new trusted jaguar shop. That did not happen in the last 3 miles.
Old Aug 25, 2023 | 07:25 PM
Chris Lutz's Avatar
Yes, it's been building up for a LONG time, today is the day it chose to fail completely. I have a Jag tech locally I will speak with first. Thanks!
Old Aug 26, 2023 | 06:35 AM
it's not a bad DIY - plan on upper shock mounts, bump stops (can use Moog part number K90460 - just use bump stop with your existing bellows), I would also look at bushings and ball joints to see if they need replacing get it all done at once (lower ball joints are a PITA but can be done DIY without replacing the entire assembly), then take it to get an alignment. Too bad you don't live nearby - we could knock that out in an afternoon
Old Aug 26, 2023 | 08:49 AM
cjd777's Avatar
Chris, been busy with company, send me a PM if interested.
Old Aug 26, 2023 | 11:50 AM
Chris Lutz's Avatar
Thanks for the replies and info Steve and Wayne! I had the bushings replaced about 2 years ago. Everything else was checked over by a Jag mechanic and checked out okay.
razorboy
Dec 24, 2022 03:42 AM
jacobmstein
Oct 30, 2022 06:58 PM
markhud
Jul 31, 2022 08:11 AM
tony chiles
Feb 4, 2014 06:13 PM
