Side lights stay on
Old Mar 6, 2023 | 08:09 AM
Tim Goz's Avatar
Default Side lights stay on
Jaguar XKR 2000 USA Canada spec, convertible
When the ignition is on, car running I can control my lighting. However with ignition off and key removed my side lights stay on.
I tried a second hand light stalk, no change.
Have slaved in SLCM, no change,
Slaved in another security module no change.
Removed all brown and black relays in turn, Lights stay on.
noticed when the slaved security module was slaved in, that if the casing touch the bodywork then the interior footwell lights and instrument lights came on.
recently upgraded my internal lights, instrument and centre consul lights to LED.
have a security module fault that wont clear, say no ignition state.
On ignition off and key remove instrument display shows green lights on indicator, the after about 15 seconds main beam and indicators flash but main beam and indicators not actually on, only indicated on the instrument display.
any ideas would be appreciated
Old Mar 6, 2023 | 08:39 AM
Jon89's Avatar
Not unusual for aftermarket LEDs to stay on after ignition switch shutdown. Some folks have resolved this issue by installing the appropriate resistors in the circuit where they installed the LEDs....
Old Mar 6, 2023 | 08:43 AM
Tim Goz's Avatar
Front side lights stayed on with normal bulbs. Rear lights are also standard lights
I dont know what the no ignition state fault on the security module means, as to how to resolve
Old Mar 6, 2023 | 09:14 AM
michaelh's Avatar
How are you reading the 'no ignition state' mesage? Some form of diagnostic tool?
Old Mar 6, 2023 | 09:42 AM
Tim Goz's Avatar
read from icarsoft tool fot Jaguar Land Rover. no fault code just says ignition state
Old Mar 6, 2023 | 03:10 PM
michaelh's Avatar
The SLCM does receive network ignition state messages, but I'd expect other issues (hood/boot/filler cover operation) if there was a problem with the SCP bus.
The SLCM only manages the reversing and fog lamps:- the body processor module is the real controller. It should be possible to extinguish any relay-controlled lamp by removal of the related relay.
Did you have any problem before replacing the bulbs, and did you disconnect the battery before removing the instrument cluster?
Separately, there is a TSB for the 2000MY cars (attached) which may or may not be related.
Old Mar 7, 2023 | 02:55 AM
dibbit's Avatar
On my 2001 the side lights are all powered directly from the BPM - no relays in between. If they are staying on that points to either the BPM itself being faulty, or whatever signal into the BPM that decides if the sides lights should be on, being faulty (the lighting stalk or maybe even the dimmer module is grounding the side light input on the BPM).
If the 2000 is the same as my 2001, OP really needs to see what is happening at the BPM side light input pin.
Old Mar 7, 2023 | 09:13 AM
fmertz's Avatar
noticed when the security module casing touch the bodywork then the interior footwell lights and instrument lights came on.
This looks to me like a ground issue. Like the module electronics have no good path to the ground post on the battery. I would start investigating all of that with a meter.
Old Mar 12, 2023 | 11:37 AM
Tim Goz's Avatar
Thanks for the advise.
Old Oct 19, 2023 | 04:10 PM
Tim Goz's Avatar
Default Side lights now turn off when ignition off
well I have no idea what changed but works ok now . Only battery drain.
I disconnect my battery at night.
jonijoni
Oct 10, 2019 09:58 AM
gmakel
General Tech Help
Mar 12, 2018 11:13 AM
magicrising
Apr 16, 2015 03:10 PM
smoggyx100
May 15, 2012 09:55 PM
rowanremote
Audio/Visual Electronics
May 26, 2007 11:05 AM
