sledge hammer
Old Aug 28, 2011 | 07:51 AM
dennisw's Avatar
Default sledge hammer
I have mint black xkr..bodywork excellent..interior very good..drives like a dream..problem..sqeel on start up goes away when warm..replaced supercharger belt pulleys and tentioner..latest two sided..took to an indi jag guy..says defo belts..still doing the same..looked at all the forum sites..all say the same BELTS..going to change the main belt and tentioner next week ..if that dosnt work may go for the big hammer..
any one go any ideas?
Old Aug 28, 2011 | 08:00 AM
avos's Avatar
First determine which belt. Just take of the supercharger belt, and start it from cold of course wihtout the belt, then you know where to focus.
Old Aug 28, 2011 | 02:21 PM
H20boy's Avatar
good tip avos! Since i don't own a S/C version, does that belt have any tensioner pulley at all like the main drive?
Old Aug 28, 2011 | 02:38 PM
dennisw's Avatar
yes both belts have tentioners..you have to take the sc belt off first to get to the main belt..top hose and fans out first step ..bit of a long job
Old Aug 28, 2011 | 03:44 PM
Glenn Barickman's Avatar
If that doesn't work
48 oz. Steel Drilling Hammer-MRF3LB at The Home Depot
Old Aug 28, 2011 | 04:53 PM
bt965's Avatar
Dennisw,
The top hose and fans don,t have to be removed to remove belts,tensioner on S/C belt has square drive recess, read instructions on JTIS . If you have a problem I dont live for from you, drop me a PM
Bob
Old Aug 28, 2011 | 06:26 PM
H20boy's Avatar
Originally Posted by bt965
Dennisw,
this doesn't happen very often...coincidence you are so very close? fine gesture bob!
Old Aug 28, 2011 | 07:31 PM
bt965's Avatar
Well anything to get me out the house and away from the brainless bint I live with!Especially on a Bank sodding holiday which it is in UK tomorrow
Bob
Old Aug 29, 2011 | 01:27 AM
avos's Avatar
No need at all to take the full SC belt of (and fans/coolant pipes) forgot to mention as I never do this myself…
You can take the tension of the belt and take it of the SC pulley. Secure the belt so there is no tension on it and can’t get entangled into the other belt. Start the car and voila, you'll know where to focus on.
You actually have a big risk when detaching the coolant hoses to spill coolant on the hose, and that actually can cause it to get squeaky too.
Old Aug 29, 2011 | 02:23 AM
direng's Avatar
Bob
A nice gesture Bob.
ps. She speaks very highly of you.
Old Aug 29, 2011 | 12:23 PM
dennisw's Avatar
The end is nie
Old Aug 30, 2011 | 05:41 AM
dennisw's Avatar
Originally Posted by Glenn Barickman
thanks for the offer..pity your so far away
Old Aug 31, 2011 | 10:00 AM
dennisw's Avatar
remove superchager belt today..sqeel coming from main belt..changed tentioner..seems ok now but will know in morning when cold..the big hammer is getting closer
Old Aug 31, 2011 | 10:10 AM
avos's Avatar
What is your vin number?
Old Aug 31, 2011 | 12:07 PM
dennisw's Avatar
ac41n42pa29240
Old Aug 31, 2011 | 12:13 PM
avos's Avatar
Then I think it would be good to also check the TSB 303-59 “FRONT END ACCESSORY DRIVE BELT 'CHIRP' NOISE”, yours falls in between the cars affected.
It doesn’t mean you are affected, but you should check the action below for just in case.
If you let me know you private mail address I can send the TSB to you.
Summary:
This Technical Bulletin has been issued to address customer complaints of a 'chirping' noise coming from the Front End Accessory Drive (FEAD) belt caused by a misalignment of the drive belt.
Action:
On a customer complaint basis only a new revised FEAD belt tensioner and a new FEAD belt should be installed and the Air Conditioning (A/C) compressor locating dowel checked for correct installation.
If the A/C compressor locating dowel is not protruding by at least 3.2mm, a new A/C compressor/PAS pump bracket should also be installed.
If a new A/C compressor/PAS pump bracket is installed the A/C compressor should then be checked to ensure that the dowel hole is not worn out-of-round. If the hole is out-of-round then a new A/C compressor should also be installed.
It would have been a waist to use the Sledgehammer already on something like this, there are far more challenging potential issues worthy of the thought
Old Aug 31, 2011 | 12:25 PM
dennisw's Avatar
Summary:
Action:
thanks for the info and your interest..my email is dennisw2009@live.co.uk
the sledgshammer is just the last resort as ive been messing with this problem for months many thanks
Poet
Feb 7, 2025 02:18 PM
aholbro1
Dec 29, 2024 06:46 PM
Poet
Oct 6, 2015 09:40 PM
Darrenmb
Sep 9, 2015 09:31 PM
