soft top problems - RESOLVED
Old Jul 23, 2014 | 05:04 PM
RaceDiagnostics's Avatar
Default soft top problems - RESOLVED
Tonight I drove the car for the first time in 2 weeks after getting it all buttoned up and the bumper back on now that the rear wing welding work is completed.
I tried the soft top but it did not operate, the rear windows dropped but that was it, no real sound of hydraulics, luckily the windows did go back up, but its now too late and dark to investigate.
Any suggestion for me to look at tomorrow are welcome.
I had to disturb the pump to get to the wing, I hope I did not damage anything.
Old Jul 23, 2014 | 05:22 PM
I would check the electrical connection to the pump did not come loose as well as make sure you did not damage the solenoids or their connectors on top of the pump when you reinstalled.
Old Jul 23, 2014 | 06:04 PM
Thanks I'll check the electrical connectors first, then get some one to operate the top while I'm in the trunk. There just seemed to be two electrical connectors, the yellow one and the black one on the heavy wires going to the pump. I was unable to separate the black one and that wire went under a bit of strain.
If anyone has a detailed sequence of events/flowchart for the electrical/mechanical systems when the soft operates that would be a big help.
Old Jul 23, 2014 | 06:49 PM
Here is the link to a TSB for the convertible sequence. you can also check Gus's site JagRepair.com - Jaguar Repair Information Resource for additional guidance on the top hydraulics
https://www.jaguarforums.com/forum/a...cal-system-pdf
Old Jul 23, 2014 | 06:52 PM
Sitting up here too late reading as much as I can.
Old Jul 23, 2014 | 07:59 PM
Gus's Avatar
Gus
Check the fluid level first. When you attempted to open the roof did the motor start? When you did the work on the wing did you remove the battery terminal? You may need to do a hard reset with the windows down the roof open and the latch parked.
Old Jul 24, 2014 | 07:41 AM
I just had another look.
The back windows go down no problem when the roof down button is pressed.
There is no sound from the roof latch while still holding onto the down button.
From the trunk you can hear the pump motor start up and spin as soon as the windows go down.
The pump motor continues to spin as long as the roof down button is held but there is no sign of any mechanical movement.
The yellow electrical connector to the valves looks ok.
The black electrical connector to the motor pump looks ok.
Old Jul 24, 2014 | 07:50 AM
Gus's Avatar
Gus
What is the level of the fluid? If the pump is running and the latch is not opening is a good indication the fluid is low. Fill it to the top embossed line on the tank.
Old Jul 24, 2014 | 08:50 AM
I think it looks OK. will that amount make a difference?
Old Jul 24, 2014 | 08:57 AM
Dennis07's Avatar
The fluid level is fine.
Other suspects:
- be sure the petcock on the pump is fully closed (clockwise).
- check around the pump fittings for any indications of a fluid leak. Even a small one can inhibit the pump's ability to make full pressure.
Old Jul 24, 2014 | 10:10 AM
Thanks guys, I must have knocked the tap, it turned a fraction and the top opened. That is a big relief as we are having the hottest summer here for 10 years!
Old Jul 24, 2014 | 10:22 AM
good deal!!! marking as resolved
Old Jul 24, 2014 | 11:20 AM
Gus's Avatar
Gus
The Petcock is often overlooked. Good deal!!
Old Jul 24, 2014 | 11:28 AM
batroute's Avatar
Isn't it great when a fix turns out to be cheap as well as simple!
Old Jul 24, 2014 | 12:16 PM
Jon89's Avatar
Always enjoy reading about problem fixes that turn out to be simple and better yet, free....
We could all use more of them....
Forcedair1
Sep 8, 2025 01:57 PM
afterburner1
Dec 16, 2015 12:12 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
