Source for A/C Compressor
Old Oct 15, 2015 | 06:56 PM
sdbill's Avatar
Red face Source for A/C Compressor
Anyone know of a non-dealer, online source for the early model a/c compressor, jag part MCA7300AE, Denso part 60-1487? I say non-dealer, as the list price at $1200, discount $1050, seems a little lofty for a standard Ford-spec Denso compressor. Probably looking for the OEM Denso product, however, as the remanufactured ones have a very bad reputation here and the after-market ones have poor quality control - hit and miss finding a good one. If you use the top manifold plate from the old compressor, the 60-1487 model is apparently a universal fit for a number of Ford family models. Perhaps available at a lower price under the Lincoln part number, et al? Any info much appreciated. Getting hot in here.
Old Oct 15, 2015 | 08:05 PM
Gus's Avatar
Gus
Try this link
Link http://m.discountacparts.com
Gus
www.jagrepair.com
Old Oct 16, 2015 | 08:18 PM
sdbill's Avatar
Default OEM Compressor
Thanks Gus for the lead. discountacparts.com does stock the Denso OEM. Will order right away before it goes out-of-stock. Thanks again.
Old Oct 16, 2015 | 08:27 PM
JgaXkr's Avatar
Try this link they are cheap & great service.
2000*Jaguar*XKR*A/C Compressor Parts from Buy Auto Parts
Old Oct 19, 2015 | 10:15 AM
sdbill's Avatar
Thanks JgaXkr. Buyautoparts.com is located here in San Diego right down the street. Always good to ask questions. You get good answers. Thanks again.
Old Oct 22, 2015 | 03:21 PM
sdbill's Avatar
Default OEM A/C Compressor a Second?
Bought what appeared to be a brand new Denso compressor from the local buyautoparts.com warehouse. Sold in a sealed Denso box with all instructions, warranties, etc. After installation, pulley bearing proved to be bad - either improperly packed to begin with (most likely) or dried out because of bad seal, whatever. Wouldn't be so bad, except this unit replaces an aftermarket one installed several months ago that developed the exact same bearing problem. Rather than take a chance on another one, mechanic installed a rebuilt pulley/clutch unit he had in stock. One more adventure in the wild world of aftermarket auto parts. As always, buyer beware.
Old Oct 22, 2015 | 04:02 PM
Gus's Avatar
Gus
Did you add oil?
Gus
www.jagrepair.com
Old Oct 23, 2015 | 09:45 AM
sdbill's Avatar
Default Oiling Compressor Bearing
Gus,
Mechanic tried both silicone and petroleum sprays. Bearing appears fully sealed and would not want to pierce it(?). How would you go about lubricating?
Old Oct 23, 2015 | 10:41 AM
Gus's Avatar
Gus
I was referring to the compressor oil that is added to the compressor Freon. If it is a bearing external to that I would call them and ask them to send you another.
Attached Thumbnails Source for A/C Compressor-img_2509-2.jpg
Old Oct 23, 2015 | 12:12 PM
sdbill's Avatar
Default Compressor Oil
Work done by certified jag mechanic, 10 years experience - oil at proper level upon recharge. Noise occurs with compressor off and pulley running at idle. Didn't want to take a chance on another faulty unit, as labor, at $300 per change-out, is beginning to hurt. I suspect a distributer may have off-loaded a suspect lot of compressors, and I wanted to be done with the issue.
Old Oct 23, 2015 | 04:44 PM
Gus's Avatar
Gus
No I get it and I am asking questions to better understand the situation. Often we do not get all information necessary.
I would be calling the supplier for the A/C unit and tell them the situation that compressor with the clutch disengaged should not make noise.
Check your PM
Dpk2313
26
Dec 14, 2015 07:11 AM
Shabo
Oct 18, 2015 11:17 PM
jal1234
Oct 16, 2015 07:46 PM
Malihide
Oct 16, 2015 10:34 AM
PaulBarrrera
Oct 15, 2015 05:10 PM
