Spun a Rod Bearing
Old Dec 28, 2015 | 07:02 PM
RJ237's Avatar
Terry,
Bob Gauff (motorcarman) is probably the most experienced Jag mechanic on the forum. Take his advice seriously.
Old Dec 28, 2015 | 07:11 PM
test point's Avatar
'ditto'
Old Dec 29, 2015 | 12:13 PM
marvin.d.miller's Avatar
I sent you more information through your email
Old Dec 29, 2015 | 12:41 PM
The Coupe's Avatar
I have both Engine Repair Course 180 and 168.
Since the 168 has BOTH the V8 and V6 I uploaded it to the large file area.
Bob-
I've downloaded Course 168 from this forum, thanks to your generosity. QUESTION: What does Course 180 have that's not found in Course 168?
Thank you!
Old Dec 29, 2015 | 04:00 PM
TerryM's Avatar
Thanks again everyone for your opinions and advice, I am taking all of it seriously.
I have taken Mr Motormans advice and started my homework on Motor Repair Course 168, and will also pass a copy on to my friend the machinist who will be helping me.
I am definitely not ruling out another motor but not till we get this one out and have a look to see if it can be saved. My kids are telling me to put in a LS1 but if I wanted a Corvette i would've bought one.
I've almost got the garage sorted and plan on beginning disassembly this weekend. I'm sure I'll have more questions.
Terry
Old Dec 29, 2015 | 05:47 PM
motorcarman's Avatar
Originally Posted by The Coupe
Bob-
Thank you!
The Engine Course 180 was earlier and was replace by 168 when the V6 was introduced.
bob gauff
Old Jan 1, 2016 | 08:24 PM
TerryM's Avatar
Made good progress today on engine removal.
The question now is, I'm working in my garage with a floor jack and jack stands. Should I remove the trans with the engine, or unbolt the trans and just remove the block?
Most of things I've seen say to remove them as one. Is there a reason for that?
Thanks in advance!
Terry
Old Jan 1, 2016 | 09:15 PM
  #28
64vette's Avatar
Suggest you seriously consider dropping in a Chevrolet LS Engine and 4L60/65/70e transmission. Jaguar Specialties
Now is the time to think about it, certainly. Your horsepower possibilities are beyond what you would ever want, and the stock Jag rear can likely tolerate up to 450 HP or more if you drive sanely.
I assure you, no one will mistake it for a Corvette, it will simply be an exceptionally fast, and unusually reliable XK8.
The fact that you can eliminate the Jag ECU and TCU in favor of the GM units is a huge plus, especially since Jaguar has decided that they won't even provide new units when these go bad ( and I heard quotes of $6000 even when they were available) and even if you find a dealer to flash a salvage unit the costs are obscene compared to easily programmed and widely supported GM ECU's.
As a comparison, for a California emission legal LS swap I performed recently I purchased a brand new 2008 E67 ECU (a far more advanced ECU than my XK8 ECU) for $390 through GM and had it programmed at the dealer for $112.
I have a good motor in mine, but am slowly getting fed up with the Jag electronics and lack of reasonable service for Jags from the previous decade.
Old Jan 2, 2016 | 09:06 PM
TerryM's Avatar
Brought it out without the transmission, took 2 of us about 7 hrs total.
Next stop is the machine shop on Monday and then we will see what happened.
If it's not salvageable, then will have to decide LS1 or find another Jag.
Old Jan 4, 2016 | 01:26 PM
  #30
halveb's Avatar
Glad you were able to get it out and hope you find that it is reasonably salvageable.
Old Jan 9, 2016 | 03:35 PM
  #31
TerryM's Avatar
Got the motor disassembled.
The bad news, as suspected cylinder 1 spun a bearing and number 2 was also ruined in the process, the other 6 look ok.
Is the AJ26 crankshaft interchangeable with the AJ27 ?
And you guys weren't kidding about the astronomical price of replacement parts!
Thanks, Terry
Old Jan 10, 2016 | 05:39 AM
  #32
Computer Budda's Avatar
Here you go.
1997 JAGUAR XK8 CONVERTIBLE PARTS CAR
Old Jan 10, 2016 | 05:52 AM
  #33
Or perhaps 1998 XJ8 Jaguar Short Block
Old Jan 11, 2016 | 08:43 AM
  #34
TC Johnson's Avatar
Don't forget your oil cooler and lines! Pacific Oil Cooler Services in California did a full clean and test of my cooler, and they are certified by the FAA. About $120 for the cooler with shipping.
If you do the full rebuild, you will be shocked at the cost of all the lower end bolts.
My rebuild was as much for my own education and pleasure as a labor cost saver. There has been a lot of satisfaction for me every time I turn the key and hear it purr. A lot of work, though.
TC
noterman
28
Sep 20, 2016 07:14 PM
Rocky15
Dec 30, 2015 06:48 AM
XJeej
Dec 20, 2015 10:15 AM
OMGPirate
Motorsports
Dec 16, 2015 09:21 PM
uncheel
Dec 15, 2015 06:37 PM
