Stall when hot
Old Dec 14, 2011 | 09:21 AM
Rip Reed's Avatar
Question Stall when hot
I Have A 1997 XK8 The part-load breather hose Is cracked and leaking can that make it Stall When I shift To Drive And Reverse When It Is Hot Not Cold Thanks For Your Help
Old Dec 14, 2011 | 09:42 AM
H20boy's Avatar
Rip, you ask two very opposite questions, this when HOT, and https://www.jaguarforums.com/forum/x...d-stall-64926/. If you're just fishing for information, can you at least keep it in the same thread? Maybe it'll get merged.
Old Dec 14, 2011 | 10:11 AM
The Coupe's Avatar
This is actually his fourth thread in two days, asking the same question.
Rip, as said before, if you give us some more information (have the diagnostic codes read and post them up here, for example), and keep your question to one thread, it will be a lot easier for the very helpful guys on this forum to respond.
Simply asking the same question (or an opposite, as H20Boy has pointed out) four times doesn't help us, or you.
We do want to help, but you gotta give us more to go on.
Old Dec 15, 2011 | 08:00 AM
oldmots's Avatar
Just to give an answer, any air leak into the engine block or heads will cause an incorrect mixture and rough running and stalls. Just leaving out the dipstick will do it.
Old Dec 16, 2011 | 06:45 AM
Rip Reed's Avatar
Thank You Much
Old Dec 16, 2011 | 08:01 AM
Rip Reed's Avatar
Question codes PO174 PO151
Sorry for all the threads i had the diagnostic codes read and the codes read PO 174 PO 151 PO 1000 I Replaced the bank 2 sensor 1 and part load breather hose it was cracked and leaking and the duck seal and i stell have the stall when it is hot and all 3 codes are are not gone thank all of you for help Thanks Rip
Old Dec 18, 2011 | 08:39 AM
Rip Reed's Avatar
Cool Codes po174 & po151
Old Dec 19, 2011 | 03:45 PM
oldmots's Avatar
The codes you are getting are for a lean condition and low voltage on the O2 sensor circuit. The cause could be a dirty air filter, a dirty or bad Mass Air Flow Sensor, an intake air leak and a bad O2 sensor. Low fuel pressure and a bad fuel injector could also be at issue.
kingdom worker
Nov 14, 2020 03:47 PM
inactualis
Oct 2, 2015 11:13 AM
JaguarSV8
Oct 1, 2015 01:58 AM
Mark SF
Sep 28, 2015 01:51 PM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
