Stalling Help!
Old Aug 28, 2016 | 10:55 AM
serafin's Avatar
Default Stalling Help!
I purchased a 1999 XK8 in May, have had no problems until yester (replaced MAF sensor in June). Driving home and suddenly car lost power, idled rough and stalled. Had it towed home, let it sit for about 2 hours and it started up, ran 30 seconds just fine and stalled again. Did the same thing this am. I appear to be getting fuel at the rail, have checked air flow, even put the old MAF sensor in. Car seems to star every 2 hours for about 30 seconds. Runs fine then idle drops, no power and stalls. I'm thinking it isn't the fuel day (I can hear it prime), I'm getting spark, or it wouldn't start every 2 hours. I've checked all fuses, wiring harnesses, and no computer codes... Any ideas what I can check?
Old Aug 28, 2016 | 11:22 AM
WhiteXKR's Avatar
Removed the ECU (with battery disconnected), open up the case and inspect the circuit board for leaking electrolytic capacitors. Signs include moisture, brown or black spots and corrosion spots.
ECUs usually can be professionally rebuilt.
Old Aug 28, 2016 | 11:37 AM
serafin's Avatar
Thanks, just pulled it out. It looks clean and ok.
Old Aug 28, 2016 | 11:45 AM
BobRoy's Avatar
Have you checked or ever changed fuel filter. It might be letting enough by to get it started but not enough to keep it running.
Old Aug 28, 2016 | 12:11 PM
serafin's Avatar
ECM looks clean, both sides, no evidence of leaking or corrosion
Old Aug 28, 2016 | 12:16 PM
serafin's Avatar
Fuel filter was replaced 11/14, along with fuel pump. I've been getting 19mpg up until now mostly driving in heavy traffic, would it fail instantly?
Old Aug 28, 2016 | 11:55 PM
jamdmyers's Avatar
I believe you have a fuel pressure regulator, while the pump would provide fuel to the rail the regulator has been know to go bad.
Old Aug 29, 2016 | 08:02 AM
ccfulton's Avatar
Have you checked the long term fuel trims?
I had a similar stalling problem when the trims were maxed out and still wanted more adjustment than the ECU could give.
It was a funny thing, because a hard reset would make it run fine until the adaptations maxed out and then the stalling while driving started. Similar behavior at idle too, start it up and would be fine until it went into full closed loop mode, then stall.
If the trims are way high, start checking for an air leak somewhere.
Old Aug 31, 2016 | 07:58 AM
Gus's Avatar
Gus
Try reading your OBDII codes and see what you come up with.
Gus
www.jagrepair.com
Old Aug 31, 2016 | 08:07 AM
brgjag's Avatar
Mine did that before I had the PCM looked out and deemed needed rebuilt, all that after 3 TB's were put on it thinking that was the issue the indy said. I was like, OK, this is the 3rd TB, still doing it, I know the PCM could be an issue, told them to get my orig TB back, put it on, got PCM back, car has been running fine since.
Old Aug 31, 2016 | 02:15 PM
serafin's Avatar
No codes P1000 (disconnected battery), I changed the fuel filter because it was easy, interesting, now not seeing fuel in the valve on the rail. I've ordered a new fuel pump (looks like a shitty job). Car will start and run for a few if I spray starter fluid into the intake. Really looks to be the fuel pump now... Will keep you posted!
Old Aug 31, 2016 | 02:23 PM
Gus's Avatar
Gus
Let me be the first to tell you NOT to use starter fluid it can cause you to crack the intake manifold. It is plastic! Use this link and check the power to the pump it has 2 fuses and one relay.
Old Sep 18, 2016 | 09:37 AM
serafin's Avatar
Thanks for the help, it was the fuel pump which i've just replaced and cat is running sweet now
Old Sep 18, 2016 | 10:04 AM
Gus's Avatar
Gus
Great!
HoosierMama
41
Sep 21, 2016 08:19 AM
Donna
Aug 29, 2016 03:30 AM
xtypejag502
Aug 27, 2016 09:18 AM
AlbBolivar
Aug 14, 2016 01:15 PM
razorboy
Aug 11, 2016 10:12 AM
