strange series of beeps-2003 XKR
Old Dec 30, 2024 | 05:31 PM
Pantera928's Avatar
Default strange series of beeps-2003 XKR
When driving this car, there will be a random case of 5 beeps like a seatbelt not buckled or a key left in the ignition on some other cars. This series of 5 beeps is repeated 5 times.
Sometimes it does this and sometimes it does not. Never and lights on the dash and no codes.
Any ideas?
THanks
Old Dec 30, 2024 | 05:37 PM
motorcarman's Avatar
Check your CLIMATE CONTROL PANEL for an ER message.
The panel can display the faults.
Old Dec 30, 2024 | 05:47 PM
Pantera928's Avatar
How do you get it to display messages other than inside and outside temps. FYI, it seems to work properly.
THanks
Old Dec 30, 2024 | 06:25 PM
here is a link to the pdf for checking the climate control system for error codes
Every thing you ever wanted to know about XK/XJ air conditioning - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 31, 2024 | 06:19 PM
Pantera928's Avatar
Well, I looked at the PDF and tried to test. THey referenced a "FACE" button. I have no idea what that is.
Anyway it toggled between a 11 and a 20.
Later, with the car running, I saw a 21, 22 and 24
Dont see a 20 in the list of codes
Old Jan 1, 2025 | 06:53 AM
Jon89's Avatar
FACE simply means the button that causes the HVAC system to blow the air up to your face....
Old Jan 3, 2025 | 08:05 PM
Pantera928's Avatar
Well, now that i have done it correctly, I have 2 codes. Not sure if wither would causes the beeping sound.
11 Motorized in-car aspirator malfunction Harness / connector fault Sensor open / short circuit Panel fault codes are not stored for motorized in-car aspirator motor failure.
41 LH fresh / recirc. motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
What is the PDU?
THanks
Old Jan 4, 2025 | 08:22 AM
Portable Diagnostic Unit
Jvaitch
E type ( XK-E )
Nov 6, 2022 12:30 PM
Kuddlesworth
Mar 31, 2022 12:20 PM
Gje307
Dec 16, 2021 01:09 PM
TexasTraveler
Mar 13, 2020 07:26 AM
dsd
Jan 2, 2018 01:21 AM
