Strut bearing
Old Apr 6, 2014 | 05:24 PM
EZDriver's Avatar
Smile Strut bearing
I came across this part that I believe is the replacement part that goes bad in the upper front strut mounts. Am I right and has anyone had any experience with using this part?
Thanks guys
Jaguar STRUT BEARING FRONT - C2S30556
Old Apr 6, 2014 | 05:58 PM
The Coupe's Avatar
EZ,
That's a part for the X-type model, not XK8 / R, at least according to the site. And having rebuilt my front strut and mount assembly, I don't recognize that part.
Old Apr 6, 2014 | 06:18 PM
Jag#4's Avatar
Nope. The XK8/R shock mount is a rubber or poly doughnut sandwiched between two metal plates. One plate has three studs that mount to the fender well.
Old Apr 7, 2014 | 03:48 AM
ArtyH's Avatar
What is the best way to check if these shock mounts need replaced? Is it a visual check, or is it felt by driving or is it a noise obvious thing? Mine look O.K but he's 16 years old and I would like to be sure things are right. Any opinion/comments appreciated.
Old Apr 7, 2014 | 06:54 AM
batroute's Avatar
Look at the shock nut from inside the engine bay(under the plastic covers on the suspension towers) - if it's way off centre the mount has perished - you will also(at that stage) be able to lever it around with a screwdriver. The other sign is a noise that sounds like birds tweeting emanating from behind the dash whilst driving- that's caused by metal to metal contact when the bushing crumbles. The ride height will also be lower but that's not definitive because other stuff(tired springs etc.) can cause that.
Old Apr 7, 2014 | 10:48 AM
EZDriver's Avatar
I was thinking that it might be the foam donut in the middle that was listed. There is another listing that I hope I can include with this post. It is the whole part
http://www.jagbits.com/mm5/merchant...._Code=C2S44944
Old Apr 7, 2014 | 12:12 PM
The Coupe's Avatar
Jaguar UPPER MOUNT FOR FRONT SHOCK - C2S44944
That's ALSO a Jaguar X-TYPE part, as the listing says. Not XK8 or XKR.
Old Apr 7, 2014 | 01:06 PM
BobF's Avatar
Try MJA2170BD Plate Upper Mtg 1.2 hrs from page 640/641 of parts list.
Old Apr 7, 2014 | 01:10 PM
This is what you are looking for:
Somebody posted recently that they couldn't find the pattern parts in stock anywhere.
trickeyM
Oct 4, 2015 05:43 PM
inactualis
Oct 2, 2015 11:13 AM
Nic1635
Oct 2, 2015 01:30 AM
HuncaMunca
Sep 27, 2015 02:47 PM
