sun visor removal question
Old Jul 9, 2014 | 06:52 PM
lawnerd's Avatar
Default sun visor removal question
My headliner is sagging on my A pillars and header. I want to replace the headliner. But, to get the header off, I need to remove the sun visors.
My question - do I need to disconnect the battery before removing the sun visors?
I slightly remember hearing that if you don't disconnect the battery before removing the sun visors you could screw up the car's CPU. Any truth to that?
JTIS says to disconnect the battery before removing sun visors. But JTIS says to disconnect the battery for almost everything.
Old Jul 9, 2014 | 07:02 PM
vettegood's Avatar
Just go ahead and disconnect !!! Why be sorry ??? It is no big deal to disconnect battery... You could of had it done by now.
Hope this helps.
And remember
Happy Motoring...
Old Jul 9, 2014 | 09:38 PM
WhiteXKR's Avatar
Disconnect the battery...it is really easy to short the visor mirror lamps to the chassis otherwise. And you are correct, the Body Control Module should just blow a fuse when that happens, but there have been some cases of it burning out instead.
Old Jul 10, 2014 | 04:27 AM
lawnerd's Avatar
Got it. Battery is going to be disconnected.
As you can see, sometimes my laziness knows no bounds.
Old Jul 10, 2014 | 03:44 PM
aardvark64's Avatar
It's also easy to remove the centre panel with the interior lights (above the rear-view mirror) and disconnect the sun visor cables from where they connect to the loom. That way, there is no fear of blowing fuses etc when you remove the visors.
Hope this makes sense.
Best wishes, Colin
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
Jandreu
Jan 23, 2017 10:58 AM
sogood
Sep 15, 2015 07:35 AM
philwarner
Sep 6, 2015 11:10 PM
