Supercharger oil change.
Old Jul 21, 2022 | 01:31 PM
Ant Buck's Avatar
Default Supercharger oil change.
What i thought to be a straightforward job turned out to be anything but. The plug removal was fiddly, but my problem was getting the tube in any distance to drain the old fluid, it did not seem to matter how much i tried it just hit a brick wall. The tube came with the kit and is obviously the right size. What am i doing wrong?. I ended up loading the syringe and putting some fresh in.
Old Jul 21, 2022 | 03:54 PM
Dr. D's Avatar
Originally Posted by Dr. D
14" Weed Whacker fuel hose (insert 6" optimum)
Would you share how your tube diameter compares to my 0.132" (3.35mm) OD 14" Weed Whacker fuel hose?
The first time I drained mine was at 62K miles, where I extracted 7oz's of coffee colored oil.
Since then, I schedule a drain and refill every 20K miles.
Old Jul 21, 2022 | 05:56 PM
XKRRANDY's Avatar
Thanks I’m on it, is there a special oil?
Randy
Old Jul 21, 2022 | 06:10 PM
Dr. D's Avatar
Randy
From my 2002 XKR notes:
Put bonnet in Service position
(2) 4 oz bottles GM 12345982 SC oil (7 oz. fill)
14" Weed Whacker 0.132" (3.35mm) OD fuel hose (insert 6" optimum)
2 oz Syringe
sponge to catch fill overflow /plug
headlamp and and led lamp to see fill overflow
needlenose pliers for hose insertion (1" increments)and to steady mini ratchet with 3/16" hex bit
flex putty knife for backing pressure on ratchet
Duplicolor Engine Enamel DE1651 Cast Coat Iron
Old Jul 21, 2022 | 07:46 PM
motorcarman's Avatar
You will need to push the small diameter tube/hose DOWN past the large gear connected to the rotor lobes.
If you try to go STRAIGHT IN you will NOT be able to continue to feed into the oil reservoir area,
Old Jul 21, 2022 | 08:55 PM
Dr. D's Avatar
Hello Bob:
I came up with inserting my 14" length of 0.132" OD tubing to a depth of 6" by trial and error. I would guess that I insert my tubing 45-60 Degrees DOWN from STRAIGHT IN.
Since I am extracting around 7oz against a spec capacity of 7.3 oz, I think that I am extracting all the oil that there is to get.
Also, I did not have success with larger diameter hose as the larger the diameter, the STRAIGHTER IN it wants to go.
I would be interested in what diameters others use.
Old Jul 22, 2022 | 03:45 AM
PKWise's Avatar
Just adding a graphic to Motorcarman's explanation.
Old Jul 23, 2022 | 02:46 AM
rod9669's Avatar
Every tube has a natural curve - insert it until you feel it stop, then rotate it whilst applying slight pressure - you'll then feel it drop below the gear. same when you're syphoning out, keep on rotating and moving it slightly backwards and forwards, surprising how much more you get out.
Guess which one was the new oil?
Old Jul 23, 2022 | 06:49 AM
Ant Buck's Avatar
Thanks for the reply, i have managed to change it this morning. there is not a lot of room but with a wiggle the pipe found it's way in. Many thanks. Anthony.
eksjaysix
XJ40 ( XJ81 )
38
Sep 30, 2020 11:01 AM
panels
Feb 23, 2015 11:48 PM
Vector
Apr 1, 2013 12:40 PM
Rique
May 31, 2012 08:58 PM
adreasx
Dec 9, 2008 05:52 PM
