#3 cylinder Id. FAQ
Old 10-17-2009, 02:28 PM
wheeble's Avatar
Default #3 cylinder Id. FAQ
Got restricted performance. Codes pulled, #3 cylinder Coil fail. #3 Cylinder misfire.
I have JTIS CD and can do this work without issues, but as simple as this seems, I can only find a diagram bank A and Bank B. and the firing order. Am I to assume cylinder 3 is the 3rd to fire in the order (bank A #4 closest to the firewall on the passenger side USA).
If someone can post a cylinder number chart it would be most helpful.
1999 Xk8 78,000 miles.
codes are as follows: P0353, P0303
Thanks.
Old 10-17-2009, 03:41 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
I know, Jaguar is real flexible with the cylinder numbering. When they refer to #3 that translates to A2.
1 2 3 4 5 6 7 8
A1 B1 A2 B2 A3 B3 A4 B4
That's how Ford/GM always numbered their cylinders. I think I saw such a chart in JTIS at one time but not today. It is probably hidden in one specific year.
Old 10-17-2009, 03:42 PM
Paul Pavlik's Avatar
Actually, These 2 diagrams show the same firing order. I assume that a Code referring to "Cylinder #3" would mean #3 on the MY 2002.5 up Diagram above.
Old 10-17-2009, 05:06 PM
wheeble's Avatar
I haved seen the diagram in the JTIS also, but after 30 minutes of looking still can't find it. Thanks for the replies guys. The Coil is $107.00 at autozone.
Old 10-18-2009, 11:56 AM
Received 9,005 Likes on 4,113 Posts
Nice info Paul...FAQ'd at test points request
Old 10-21-2009, 08:06 PM
wheeble's Avatar
Default Update
#3 cylinder coil replaced as shown in the diagram supplied by Paul. Codes cleared, car back to running like a top.
Another note of intrest to USA forum readers, I purchased the coil from AutoZone, turns out thier coils are OEM. $107 The dealer part was $135
Thanks again
Old 10-22-2009, 12:06 AM
wheeble's Avatar
no residue, the coil looked like the new one. I think they just break down over time and heat makes them fail after acertain amount of time. the tube and boot was clean and dry.
PhilXJ6
01-03-2016 08:55 PM
Delta66
10-04-2015 05:40 PM
sandmann62
10-01-2015 09:31 AM
baskervillema
10-01-2015 01:59 AM
Quick Reply: #3 cylinder Id. FAQ
