Tensioners, good news or bad?
Old May 23, 2020 | 02:18 PM
The zip tie keeps the chain located on the sprocket so the timing remains correct.
If the chain comes off the sprocket you will need the timing tools to reset.
Old May 23, 2020 | 02:56 PM
brinny's Avatar
Yes I have got that part. After watching it again closely on you tube it appears the cam is just eased up slightly to allow removal and back down. Same again on installation. It looks like it doesn’t move very far at all.
Old May 23, 2020 | 03:28 PM
NBCat's Avatar
Given the age of the vehicle and the fact the secondary tensioners have cracks, it's false economy to just replace the secondary tensioners on an AJ-V8.
Replace the primary and secondary timing chains, guides and tensioners as the primary guides often crack or pieces break off and end up in the sump, if that hasn't already happened.
Here is a link to the AJ Engine Course with instructions on how to correctly install the timing chains:
https://www.dropbox.com/s/vqpy3bbjzd...e_168.pdf?dl=0
Pay particular attention to the instructions beginning on page 24 of the course (page 72 of the PDF). Note correct camshaft timing is 45 degrees ATDC not TDC as some people insist on using.
In addition there are two other things to bear in mind whilst replacing the timing chains:
  • Under no circumstances is the engine to be rotated in an anti-clock direction when viewed from the front of the vehicle as damage to the main and rod bearings is the result
  • Use the correct tools shown in the Engine Course. DO NOT use the crankshaft holding tool to hold the crankshaft whilst removing the centre bolt from the crankshaft pulley
Old May 23, 2020 | 03:31 PM
giandanielxk8's Avatar
I know the 4.2 engines are good on the secondary tensioners, but what about the primaries?
Old May 23, 2020 | 03:39 PM
NBCat's Avatar
The AJ33 and AJ33S both use Morse primary chains and do not typically fail. I have seen broken secondary tensioners on the AJ33 due to failure of the plastic 'slipper' surface, which cracks and can fall out causing the secondary timing chain to become slack.
The best method to use on any AJ-V8 is to remove the cam cover(s) and inspect the secondary chains and tensioners for cracking, breakage or slackness. Use a bore scope to inspect the primary tensioners and guide rails.
Old May 23, 2020 | 03:41 PM
brinny's Avatar
pennies dropped at last!
Old May 24, 2020 | 02:26 AM
dibbit's Avatar
Just put the cam covers back on and take it to a specialist.
Old May 24, 2020 | 02:36 AM
  #28
brinny's Avatar
As they say it's easy if you know.
Old May 24, 2020 | 10:14 AM
bcprice36's Avatar
brinny,
As I said, "The Check gets Bigger, the longer you wait"! Take it to the Shop! You can't do this with a "Crescent" Wrench and Pair of Plyers!
Billy Clyde
Old May 24, 2020 | 11:04 AM
  #30
brinny's Avatar
Will let you know how I get on. Many thanks for your superb help.
Old May 30, 2020 | 09:34 PM
  #31
Syb Drylst's Avatar
Originally Posted by bcprice36
brinny,
With the last question you asked, I'm not sure you should try to do this job! My advice is to have the Jag hauled to someone that knows how to do the job....get it done right and forget about it!
This problem occurred years ago to my 1998 XK Coupe! All I did was start the Engine and all Hell broke lose. Cost me several Valves and a New Piston...are (2)! This is what you are looking at...…..so take the advice of almost everyone on the Forum that knows anything about the XK8 or XKR...….Do it NOW!!! It has been awhile for me but I'll never forget the feeling and the writing of the BIG check!
Billy Clyde
If you let a shop do it let them to change the crankshaft seal to ,they have a short life mine was leaking at 65000 km.
Just saying
AZjag1999
Nov 10, 2018 09:27 PM
Shotimer
Jan 13, 2016 11:31 AM
noonblueapples
Apr 24, 2015 08:38 PM
19hankster
Dec 2, 2010 09:06 PM
cpm53
Apr 16, 2010 09:25 PM
