Test unit
Old Jan 24, 2024 | 02:05 PM
Mithrilweaver's Avatar
Default Test unit
I have a 2001 xkr convertible. I have read many threads before I asked this. My question: What is a test unit that will read all the codes of my OBDII. Can someone recommend something current? Where to get one? Multiple options? My craftsman will read it, but not translate all codes.
Old Jan 24, 2024 | 03:43 PM
michaelh's Avatar
I'd beware of any reader's interpretation of DTCs other than Jaguar's proprietary diagnostic tools. If you have the codes, then refer to Jaguar's DTC lists:- I've attached the MY2001 P-code documentation.
File Type: pdf
Old Jan 24, 2024 | 10:44 PM
What I wanted to know is, what specific unit to use, (which I suppose you answered in a way, without giving its name) and where to get one. Thanks for the pdf file. I am sure it will be extremely helpful.
Old Jan 25, 2024 | 11:55 AM
Y2KJag's Avatar
The only one I've seen (and I don't own one) is the "Mongoose" cable and the JLR diagnostic software. Here's a link to one company in the UK who sells it. There may be others.
https://www.jlridssddmongoose.com/
I have access to several good scan tools and none of them work for everything on these cars. A very old Autel MaxiDAS will read every module, but can't reset some codes, like ABS. A newer SnapOn will do most, but hangs up and crashes when reading the trans controller. A newer Autel won't go back to 2000. A new DrivePro will clear all codes but can't read the trans controller. It's all very frustrating. The electronics, while somewhat sophisticated are still very primitive, even compared to contemporaneous low-end BMWs.
I've been lucky and have been able to cripple by with these. If you can only get one, I'd suggest springing for the JLR Diagnostic kit.
Old Jan 25, 2024 | 05:15 PM
Any other suggestions? Did Jag abandon the technology or something?
Old Jan 25, 2024 | 05:22 PM
Y2KJag's Avatar
Pretty much. These cars had a very limited production, and are now 20+ years old. There's no money in it for Jag so they couldn't care less. They'd prefer you bought a new one, and I doubt they'd shed many tears if they all went to the crusher.
Old Jan 26, 2024 | 08:42 AM
Coventry Foundation's Avatar
Mithrilweaver the Coventry Foundation placed a working WDS unit (loaded with IDS) in selective and strategic points in the US. In Texas the WDS is under the protection of the Jaguar Owners Association of North Texas. You can find their contacts on the JCNA web site. Warning--this unit is not portable so you must go to it. You also need some experience with it to use it. That said folks come down from Oklahoma and up from Houston to fix issues. Best wshes.
Old Jan 26, 2024 | 08:52 AM
Jon89's Avatar
Coventry Foundation,
Do you maintain any working WDS / IDS systems here in North Carolina? It would be good information to have in the event that I need to access one....
Old Jan 26, 2024 | 10:10 AM
John closest to you is Columbia, SC.---perhaps 3.5 to 4 hours?
Old Jan 26, 2024 | 01:17 PM
Jon89's Avatar
^^ How do I get in touch with them?
Old Jan 27, 2024 | 06:34 AM
Have you tried the web site? www.coventryfoundation.org ????
Old Jan 27, 2024 | 06:48 AM
Jon89's Avatar
Thanks, I will note this if needed for future reference....
Old Jan 27, 2024 | 09:35 AM
RJ237's Avatar
The Launch X431 pros mini and probably other variations will read all codes and real time data for over 100 different makes. I have used it on both my Jag and Maserati.
Old Jan 29, 2024 | 12:02 PM
Y2KJag's Avatar
Hi,
I looked at your site (very nice, BTW) but didn't see the information I was after. Do you have anything in the Los Angeles area?
TY
Old Jan 30, 2024 | 07:05 AM
We have a unit in Oceanside. It is under the control of volunteers from the San Diego club. And thanks for the compliment.
Old Jan 30, 2024 | 09:10 AM
motorcarman's Avatar
I can read and print all the DTCs in all your modules with WDS or IDS (I have BOTH) but you are about 150miles away.
If you plan a road trip East, let me know.
Bob
Wise County TX
HeinzXtype
General Tech Help
Aug 28, 2022 04:25 PM
coronets
May 29, 2019 12:23 PM
BlackEagleS
Sep 23, 2012 05:36 AM
Per Greibe
Mar 14, 2011 01:11 AM
Oklahoman
Mar 7, 2011 12:19 AM
