Tilt wheel
Old Apr 25, 2021 | 08:44 PM
tjankovs's Avatar
Default Tilt wheel
Hello...after 15 years in intermittent operation my tilt wheel is stuck fully extended and fully down. This is where I typically drive, so not the worst problem to have, but it would be nice to move it to get out. I hear the motor click when I try to lower it against the hard stop, but no other direction has any effect. Any ideas how to restore operation?
TJ
Old Apr 26, 2021 | 07:55 AM
David Dougherty's Avatar
Default Had the same problem
TJ
I never use the automatic tilt away feature when one day I was fooling with the steering wheel and it got stuck completely at the in and up max position. Regardless of what I tried all I could get was the clicking sound. As a last resort I moved the control knob to the out position, the clicking started and with my free hand pulled the steering wheel towards me not really very hard but firm. The wheel came out back no clicking and the system works as normal but not at its limits I assume.. Of course I am going to leave it alone but as yours seems stuck also at the end of its travel this may work.
Old Apr 27, 2021 | 02:25 AM
This issue has been discussed on X308 forum and the XK8 the tilt/reach setup is similar. Have a look at these threads:
https://www.jaguarforums.com/forum/x...-broken-45241/
https://www.jaguarforums.com/forum/x...-1998-a-17191/
Removal procedure from JTIS attached.
Old May 1, 2021 | 09:36 PM
tjankovs's Avatar
Thanks for the info! I think I will turn off the AUTO feature since it is in a good position. Looks like there have been a lot of problems with this system.
TJ
martymclendon
Feb 15, 2020 02:37 PM
Y2K XKR
Jan 13, 2018 02:18 PM
Cabel
Jan 9, 2017 07:09 PM
Frog
Jun 7, 2011 05:17 PM
JamesWalker
May 7, 2011 10:10 PM
