Time to replace the engine
Old Nov 13, 2012 | 09:51 PM
Jeff in Tucson's Avatar
Default Time to replace the engine
The oil leak that developed is oil that is blowing past the piston rings. The compression in the 2 passenger side rearward cylinders is 18%. The others are around 8.
The car is still quite drivable, but has a slow excretion of oil when used. I have time to decide what to do, plus I have another vehicle to drive that is reliable.
So... I'm considering purchasing a used engine to replace mine which has 147,000 miles on it. After doing that, and installing the twin screw supercharger kit from AVos at the same time, I'll begin the process of having a brand new custom engine built and balanced over the following year.
Does anyone happen to have a 4.0 engine available for MY 2000 XKR? Also interested in input/ideas.
Many thanks!
Old Nov 14, 2012 | 01:34 AM
H20boy's Avatar
...just checked in my garage, nope...
Old Nov 14, 2012 | 05:44 AM
JgaXkr's Avatar
I have a 4.0 block complete that came from my car as well as a brand new pair of 4.2 cylinder heads. All of which I would love to sell.
Old Nov 14, 2012 | 06:03 AM
Originally Posted by Jeff in Tucson
The oil leak that developed is oil that is blowing past the piston rings. The compression in the 2 passenger side rearward cylinders is 18%. The others are around 8...................
That's a killer when you put as much time, effort and $$ into getting the vehicle right.
Old Nov 15, 2012 | 01:16 PM
The car still runs pretty well, but I have to put up with the smell of oil while driving. I'll be cutting back on driving the Jag while I prepare to get the other engine and have the supercharger installed.
AVos has suggested going with a 4.2 and I've found a couple of them with low miles for sale. Now, I'm just waiting for another sale to come into my business so that I can justify the expediture. =) I'll get there.
Old Nov 15, 2012 | 03:37 PM
Reverend Sam's Avatar
Why not just rebuild the engine and put in new rings and everything? It would make a REALLY COOL video. :-) Or do you think the cylinder walls are shot?
Old Nov 15, 2012 | 03:46 PM
Beav's Avatar
I'm with Sam. Building on top of an unknown really isn't the direction I'd take. And by 18% I assume you mean leak-down, not compression?
Old Nov 15, 2012 | 07:22 PM
JgaXkr's Avatar
Did your oil consumption start after you installed the waterbmethanol kit? I replaced my engine for a similar problem.
Old Nov 15, 2012 | 07:56 PM
Gus's Avatar
Gus
Add a can of Restore and see what takes place. I would say you would be satisfies with the results and that would give you a little extra time to find the right engine if you need to change it.
Old Nov 15, 2012 | 08:07 PM
plums's Avatar
Being in Tucson, perhaps a thicker oil would help ... at least in the shorter term.
Conventional 15W40 is available in Shell Rotella.
Old Nov 22, 2012 | 08:42 PM
Default 4.2
I've decided to go with a 4.2 as AVos has suggested. A gracious friend of his, not a member of this forum, had offered to help me with use of an engine, but it is a 4.0 and I'd have to ship it to the US from the Netherlands.
The 4.2's injectors flow at a higher rate and will help to generate more horsepower.
The car is still running fine, but with a slight oil smell after it gets warmed up (oil leaking into the air filter intake box due to blow-by).
I will use the RESTORE product to see if that helps.
Restore USA - Engine Restorer Test Data
Old Nov 23, 2012 | 12:31 PM
Default So far, no oily smell while driving
I added a can of RESTORE to the engine oil this morning, then went for a drive. Within minutes, the oily smell that occurs after the engine warms up WENT AWAY. I wonder if it really has temporarily sealed the piston rings against the cylinder walls better. Hmmm. So far, it was worth using it just for the elimination of the oil odor. =)
Old Nov 26, 2012 | 02:53 PM
There seems to be a bit more power in the engine. I usually drive with the traction control turned off. I pulled into a major street today with oncoming traffic. The car was almost at a straight approach, similar to entering the highway from a ramp entrance. I had to lift off of the throttle because I realized that my right rear tire was spinning and smoking. I'm sure that it looked like I was showing off to others, but I didn't know that would happen. The elimination of the oil odor continues.
Old Nov 26, 2012 | 03:16 PM
Gus's Avatar
Gus
Restore is a good product and yes it will at times provide a little better performance. If I thought it was snake oil I would not recommend it.
Old Nov 26, 2012 | 06:49 PM
plums's Avatar
Thumbs up
Excellent. The product has been recommended many times on JF by Brutal.
Hopefully you'll keep this thread updated with the results as a sort of real life experience review of the product.
Old Jan 2, 2013 | 07:33 PM
There had been some 'piston slapping' noise prior to using the RESTORE. When cold, the knocking would come on quickly under moderate acceleration until the engine heated up.
About 3 weeks after using the RESTORE, the sound disappeared. It has never come back.
Old Jan 3, 2013 | 02:57 PM
NikasilNik's Avatar
Sounds like RESTORE does actually work !!!!!!!!
I , like others probably , thought it was "Snake Oil " , how wrong can you be
How many miles have you covered after installing the RESTORE Jeff ??? and have you had/done a blow-by test since ???
Happy New Year
N1XKO
Old Jan 4, 2013 | 08:42 AM
Default No official tests
No official tests have been done after the use of RESTORE. There is occasional blow-by oily smoke that comes out of the intake, which could be killed with the use of an oil separator. It is greatly reduced now, though. The power is still UP. There is no knocking sound whatsoever (it had been REALLY annoying). The motor runs STRONG. I have driven approximately 2000 miles since I began using the blue goo (make sure to shake the hell out of the can prior to opening and use). The deposit of oil drops on the pavement in my parking space have greatly decreased. I'm going to re-seal the driveway after I put the 4.2 engine in! =)
I used one can, initially, liked the improvement, then added a second can, at which point the piston slapping disappeared. I added a third can a few weeks later but things have remained the same (there was some minimal oil loss so I replaced it with RESTORE instead of oil). It's not like I'm going to ruin my already worn out engine.
I drive this car everyday as my daily driver going approximately 20-40 miles per day. I drive aggressively, using the vehicle's power and handling whenever other vehicles are not around. I LIKE to drive. Would I recommend driving across the country with this engine? No. Is it possible that it would make the trip reliably? Yes!
BrentGardner
29
Dec 16, 2024 12:13 AM
lobsterD90
Nov 12, 2022 09:51 PM
MarathonJohn
Sep 3, 2015 07:59 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
dpappyp
Aug 27, 2015 06:31 AM
